BIKELAND > FORUMS > ZX-14.com > Thread: front end lowering NEW TOPIC NEW POLL POST REPLY
captainm40
posted March 05, 2012 08:08 AM
front end lowering
I was wondering if someone could give me advice on the front end lowering. I've lowered
the rear of my bikes before that's no problem.but lowering the front not sure if i should just raise the front forks are use that progressive suspension drop-in front lowering kit .and does that work on a sportbike. I want to lower the rear 1 inch and the front a1/2 inch on a zx14r and if just 1 or 2 inches rear do i need to lower front. thanks for any advice you can give
fullthrottlekaw
posted March 05, 2012 08:54 AM
you can lower in the forks through the trees but dont go over 1 in for street riding. ive also wondered about drop in fork springs by progressive suspension and how well it does on a mostly street ridden bike and how hard is it to go back to normal springs in the front if you ever wanted to do so?
Beondwacko
posted March 05, 2012 10:22 AM
FYI: on my )08' , I lowered the forks in the trees .75". With the bike strapped down tightly, there is next to no clearance. I even have a couple of very small marks where the upper fairing hex bolts touched the fender.
captainm40
posted March 05, 2012 03:28 PM
thanks and can you ride on the streets with the front end strapped down a little
Newf14
2007 ZX1400
posted March 05, 2012 04:11 PM
I had mind dropped down in the trees .75" that worked fine. I installed the muzzy 1.5" lowering blocks in the forks over the winter. I have a lowered pan so it shouldent be an issue.
Newf14
posted March 05, 2012 04:59 PM
Captainm40, you don't want to ride on the street with the front strapped. When you try to brake, or hit bumps, there is no room for the front suspension to travel.
I pull my strap just enough to keep it from flapping if I ride it to town, but I don't ride very far, and honestly I wouldn't suggest anyone else doing it
BobC
posted March 06, 2012 01:44 AM
That's good advice I have done LSR with the front strapped down tight and it bounced on the tire when the front wheel hit any bumps. The solution was to raise the forks half an inch through the triple trees and then strapping back to the same height left a little suspension movement. That small amount of damping made a crucial difference. I wouldn't ride it strapped on the street either.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
captainm40
posted March 06, 2012 03:45 AM
Thanks alot guys your advice is very helpful.
0.2419650554657 seconds processing time
