BIKELAND > FORUMS > ZX-14.com > Thread: 09 charging system blues NEW TOPIC NEW POLL POST REPLY
tnt
posted February 24, 2012 08:43 PM
My 09 has 5600 mi. on it , and the volt meter at startup usually shows around 12.8 , then after a few second goes to about 13. 4 , but yesterday it dropped to 11.8 and stayed ! I figured the batt went south , so I pulled it , and popped the seal off and it was dry ! I put some distilled water in it and put it on a trickle charge, then put my atv batt on it just to prove to myself it was the battery ! Still stuck on like 12.2 vlts, but if I revit to 5grand , it goes to 14.3 but after 15 seconds it drops back to 12.2 ? My hand held meter shows the bike to be building charge , and idles at 12.8 ? I even tested the stator AC volts , and it was charging ? Did the dry battery fry the regulator , or is the dash meter incorrect? I was fixing to buy a Shorai , or Ballistic anyway , but I need to race this weekend , and don't know what to do now??? I hate to waste 50 bucks on gas , just to have my bike crap out ! Bike never failed to start , I rode it ovr 100 miles this week , now I'm confuzed as hell , and I got some bad busass coming in to to try and spray me down !! An answers on the charging ??
posted February 24, 2012 09:03 PM        Edited By: smokinZX14 on 25 Feb 2012 05:06
My meter on both my 06 and 09 did strangs things at times .. I really don't think you have a problem other than you need a new battery .. Make darn sure you charge the new battery for 4 to 6 hours before you install it .. I have seen mine as low as 12.2 and as high as 13.8 .. My 2012 goes to 14.8 at times .. You can test them Volt reg and but i don't think its a problem .. If your stator didn't show an open or a short to ground with an ohm meter it's fine also..
tnt
posted February 24, 2012 09:22 PM
Smokin , the only test I did was the AB AC BC test , and I got about 55v at 400o rpm on but one of em didn't come up as fast or as high ?? can I check theeach wire with ohm to grd like on a HD ? Also My other battery is a YTX14BS 12ah , and the OEM is a 14h , could this cause any problems this weekend , I really don't want to buy another lead battery ? I'm gonna order a new lithium next week , if I can figure out which one ! Thanks
0.25530409812927 seconds processing time
