BIKELAND > FORUMS > ZX-14.com > Thread: 14r Horn Button For Shifting NEW TOPIC NEW POLL POST REPLY
Wheelie
Old Man
posted February 21, 2012 06:44 PM
trying to hook up my horn to the solenoid, I run the ground wire from the horn to the solenoid and it shifts when I turn the key on, I'm wanting to use the horn button if possible but it doesn't want to work. I have the ground disconnected from the horn itself, would it matter if it's connected to the horn or not?
wee
KAWITOM
My 12R gone but not forgotten
posted February 21, 2012 07:21 PM
Wee give me a call I will explain how to do it, did mine and it works fine, i can fax you a copy or email you one just give me a call if you don't still have my number, I will send you a PM
2012 ZX-14R SE
2002 VULCAN MEAN STREAK (11.41 @ 114 best 1/4)
I BLEED GREEN
06redzx14
posted February 21, 2012 07:21 PM        Edited By: 06redzx14 on 22 Feb 2012 03:21
Use a test light and make sure it's the wire that goes to ground when the horn button is pressed.
KAWITOM
posted February 21, 2012 07:44 PM
Wee this is how to wire up your air shifter to your horn button and still use the horn when your not using it as an air shifter. any questions give me a call, mine works great already tried it out.
I mounted the toggle switch to the left of the tach and velcroed the relay to the ram air tube
2012 ZX-14R SE
I BLEED GREEN
KAWITOM
posted February 21, 2012 07:47 PM
By doing this you are turning the horn system back to a ground system for activating like the 06-011 fourteens. Sorry tried to make it neat and orderly was a long day at work.
2012 ZX-14R SE
I BLEED GREEN
BrucerZX14
posted February 21, 2012 07:51 PM        Edited By: BrucerZX14 on 22 Feb 2012 03:52
I used a DPDT switch. It has 6 connection points(looks like the number 6 on dice). I took the horn switch across the 2 center connectors. The air shifter across one of the sides and the horn across the other. Works perfect and no relay needed.
KAWITOM
posted February 21, 2012 07:57 PM
Brucer that's fine if you have a 06-011 fourteen those horn systems work off a ground activation from the factory. The 2012 uses 12v + coming from the fusebox through the switch down to the horn and the other wire on the horn goes to ground totally opposite of an 06-011 thats why you need the relay.
2012 ZX-14R SE
I BLEED GREEN
Lucky14
posted February 22, 2012 04:45 AM
So if you don't care about the horn working, race only .........
1. Cut both wires attached to the horn button.
2. Ground one wire.
3. Extend the other wire and attach to the air shifter.
1badzx12r
posted February 22, 2012 05:18 AM        Edited By: 1badzx12r on 22 Feb 2012 13:20
2. Ground one wire.
and ground the air sileniod . and run it as a 12volt positive system .. if i'm seeing this right
BrucerZX14
posted February 22, 2012 05:46 AM
2. Ground one wire.
Yep. The air shifter solenoid ground can routed to the horn button and the then ground the other wire coming off the horn.
Hayabusa14
posted February 22, 2012 05:48 AM
What about the "MPS" sportbike airshifter wiring harness, will it still work?????
2012 SE-ZX14R [CT Meg-PC5 with street map-Evil swingarm 64" wheelbase-JRI shock], 2009 GSXR 1000, 2008 B-King, 2007 SE-ZX14 "Brocked out" - 1999 Hayabusa "stage 1" Turbo
1badzx12r
posted February 22, 2012 05:51 AM        Edited By: 1badzx12r on 22 Feb 2012 13:53
kawitom said ..the horn button is hot 12volt.. that would means you ground 1 wire from the silenoid to the frame and run 1 wire to the horn button..
06redzx14
posted February 22, 2012 06:44 AM
no I think this is why smokin had problems with his
1badzx12r
posted February 22, 2012 06:54 AM        Edited By: 1badzx12r on 22 Feb 2012 15:06
correct the mps trigger wire works off a negative source .. can't hook that to 12 volt positive.. but there should be a way with using the relay to trigger ground by using the horn switch as the power source for the relay.. i think maybe
Lucky14
posted February 22, 2012 10:30 AM
Yes, this one incorporates the relay to make it easier to set up.
http://www.mpsracing.com/instructions/MPS/Switch%20Swapper%20Horn_Shifter.pdf
With a relay, pushing the horn button sends a ground to the blue wire on the autoshifter, regardless of whether the horn button supplies ground or 12 volts.
Wonder why Kawasaki made an "unnecessary" change to switch 12 volts at the horn button instead of switching ground????
posted February 22, 2012 10:33 AM
Looks like a real PITA. I might just get the PMR button assembly...
Hayabusa14
posted February 22, 2012 12:42 PM
Lucky14
Do you think the MPS (1-0285 sportbike airshifter wiring harness) will work. The reason I'm
asking is I have already order it and it will be here tomorrow. Just want to know if I need to order something else. Thinks
Wheelie
Old Man
posted February 22, 2012 12:46 PM
you sure the horn isn't bk/y and bk/w ?
wee
Lucky14
posted February 22, 2012 01:19 PM
Lucky14
Since there is no relay, I would say it will NOT work on the 2012.
KAWITOM
posted February 22, 2012 02:47 PM
Lucky it will still work you just have to put ina 30 amp relay like the picture I drew and a toggle switch than you can still use your horn when not shifting, Wee the colors for the wires brown/white and black/white from the handlebar controls to the connec tor those are the only wires you have to cut and reroute the wires from the connector to the horn you don't have to mess with anything if anyone has any questions just shoot me a pm, i will be gald to help mine works great.
2012 ZX-14R SE
I BLEED GREEN
1badzx12r
posted February 22, 2012 03:06 PM
in your drawing it don't show no wire from an AUTO SHIFT BOX or KILLBOX . unless your tieing in after the relay on the wire to the air shifter.. Which i can see that
posted February 22, 2012 04:04 PM
After my air shifter fuck up i didn't use and of the factory horn wiring .. Mine using none of the factory stuff .. I'm using the MPS auto shift but i added a safety override button just in case ..
1badzx12r
posted February 22, 2012 04:09 PM
wee's hard headed
Wheelie
Old Man
posted February 22, 2012 04:20 PM
wee's hard headed
Squatch, GSXR-1000 is lighter.
wee
Lucky14
posted February 22, 2012 04:40 PM
Agreed. I was saying that it will not work - as delivered from MPS.
The link I posted to the other MPS part includes the relay and makes it easy for people that don't know or care to know how relays and switches work.
0.25806212425232 seconds processing time
