BIKELAND > FORUMS > ZX-14.com > Thread: should there be an oring here?? NEW TOPIC NEW POLL POST REPLY
codyc_13
posted February 17, 2012 10:07 AM        Edited By: codyc_13 on 17 Feb 2012 18:08
I was going to put my cut oil pan on and realized it looks like I'm missing an oring, I don't think it had an oring when I pulled it off, but it sure looks like one goes there.
This is the "stud that goes into the oil pan to hold it into place, no oil flows through it or anything and the only purpose an oring would have is to hold it securely into place.
8.97 at 149mph
kaw-rick
posted February 17, 2012 10:30 AM
no.
kawasakijockey
posted February 17, 2012 04:18 PM
No Cody, the oring is in the engine block where the other end goes up against.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
posted February 17, 2012 04:42 PM
+1, and make sure it is still there!
codyc_13
posted February 17, 2012 04:45 PM
The part that I'm pointing at does go in the bottom of the oil pan, right?
8.97 at 149mph
kawasakijockey
posted February 17, 2012 04:51 PM
Yes it does.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
codyc_13
posted February 17, 2012 04:52 PM
all the orings that i have are all attached to that rod, the only other oring was for the oil pressure sensor.
there are 3 orings attached to it, i didnt see anymore.
8.97 at 149mph
kawasakijockey
posted February 17, 2012 04:55 PM        Edited By: kawasakijockey on 18 Feb 2012 00:57
That one should be up in the block, not over that nub. There are 2 orings only on that oil tube. Or was there a design change after 07 ????
2007 ZX-14
1.38 60ft
9.03 @ 149mph
codyc_13
posted February 17, 2012 05:05 PM
Crap, must have came out with the oil pan. I left it on the oil tube when i reinstalled the pan. Should I pull it back off, its going to end up on the tube anyway isn't it?
8.97 at 149mph
kawasakijockey
posted February 17, 2012 05:39 PM
My opinion is putting it where it goes. Just an opinion.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
codyc_13
posted February 17, 2012 05:50 PM
Ok thanks, looks like I will pull it all back apart. Didn't realize it was suppose to be up in the block.
8.97 at 149mph
kawasakijockey
Oh, Evadale is cancelled too.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
codyc_13
posted February 17, 2012 05:58 PM
I saw that, looks like I have plently of time to pull it back apart now.
8.97 at 149mph
0.23657608032227 seconds processing time
