BIKELAND > FORUMS > ZX-14.com > Thread: crankshaft replacement NEW TOPIC NEW POLL POST REPLY
Russell
posted February 06, 2012 01:00 AM
I need to replace the crankshaft in my 2007 ZX14 - does any one know if a used part is viable? and if so where to look for one? Thanks.
NINJA12
posted February 06, 2012 04:15 AM
yes, and in the classified here.
also check the aucton site.
Seno
BANNED FOR LIFE!
posted February 06, 2012 05:25 AM
Since your going to do the crank have you thought about a stroked crankshaft? With a strokes crankshaft, +2mm pistons, head porting and cams you will have a serious beast.... If your going to do it, might want to "build" the bottom end first, then do the heads & cams later so it's not such a big hit on the wallet... Just a thought.
wrongway
posted February 06, 2012 06:30 AM
you should try to figure out why you had the problem. If not you may be replacing parts just to see the same problem again:-(
Roy
Russell
posted February 06, 2012 11:24 PM
Thanks guys.
For me the beast is serious enough already!!
As to what the cause was - good point - might have been the oil pump which will be replaced just in case. It happened when I got a bit excited taking off from the lights trying to drag someone - bounced off the rev limiter in 1st....
Russell
posted February 06, 2012 11:30 PM
Excuse my ignorance - but where do I find the classifieds and the auction? Thanks.
MotoCycho
posted February 06, 2012 11:35 PM
You spin #3 rod bearing? I spun #3 on my 07 about 3 yrs back.. swapped in an 09 low mile donor motor which has been great.. knock on wood! Anyway.. I sent the 07 crank to A.P.E. to have it fixed. You ought to see what they can do with your current crank.. all is not lost.
http://www.aperaceparts.com/crankwork.html
1badzx12r
posted February 07, 2012 08:18 AM
this the route i would go .. i've purchased 2 used cranks that both were said good but were out of spec.. i don't buy used cranks no more
Russell
posted February 07, 2012 04:37 PM
I took the crank to a local guy that fixes em - and he said some people would repair it, but it would be dodgy. I found a second hand one in Victoria Australia (I'm in Perth Australia) crank and rods for $950, but there is the risk of out of spec, though I could probably return it and get a refund. You wouldn't believe how much parts cost here - just the crank alone costs nearly $1800 and it would be around $2500 by the time you include conrod, bearings etc. I found a site there in US kawasakipartshouse.com that can supply everything for $1100 including freight to here. All I need now is the $1100! Must check my lottery ticket!!
It was number 4 bearing - hammered into a wafer thin state extruding metal from the edges!
kaw now
posted February 07, 2012 05:51 PM
If all that metal went through the engine then it might be a candidate for a complete engine tear down. Did you look at the oil filter and the oil pump could have traces or damage. All the oil passages might have to be flushed if the filter bypassed.
Russell
posted February 08, 2012 12:26 AM
Thanks for the advice, much appreciated
FAST Z14
posted February 08, 2012 12:36 AM
Why not look for a complete used motor, it might be cheaper than to do all those repairs.
FOLY HUCK
0.27580404281616 seconds processing time
