BIKELAND > FORUMS > ZX-14.com > Thread: Clufch question NEW TOPIC NEW POLL POST REPLY
kaw now
posted February 05, 2012 07:06 PM
Clufch question
Out for a ride today and realize that my foot feels a notchy grind at every shift. Feels like clutch dragging or not being totally disengaged. Anybody have this happen? When I Stop it feels normal no low idle smooth engagement only 400 miles on oil change 32k on 06 bike. Trying to figure out if it is a warped clutch disc or the slave/master cylinder weak. Happens even when I pull the clutch all tbe way in and wait to shift.
posted February 05, 2012 07:14 PM
Time for a clutch ...
kaw now
posted February 05, 2012 07:31 PM
Thanks for the reply. Think maybe it's warped? I don't drag race just hammer on it on rides. Guess I'll have to take it out have a look. What do you recommend stocker or what?
Wheelie
Old Man
posted February 05, 2012 07:34 PM
32,000+ miles on a oem clutch? Maybe you should stay with oem, just a thought,
wee
posted February 05, 2012 07:38 PM
No it's not warped ... It's just worn out ..When you pull the cover you will see the last clutch plate is clocked different than all the others .. When the clutch wears out that last plate gets stopped by the basket and causes what you are feeling ..
You best clutch is the factory clutch ...replace all the steels and fibers and springs and you will be good to go for another 32k ..
kaw now
posted February 05, 2012 08:01 PM
Ahh thank you again guys good wisdom there.
zx12mark
posted February 05, 2012 11:06 PM
i `ve got 55,000 on the original pack.225 drag strip 1/4 runs. i have only changed the small fiber a few times cause it would be in 10 piece `s.i do have a dale walker ps3 push button electric shifter.1.6`s are the best 60 foot i can get.stock wheel base 9.6 @145
0.23370003700256 seconds processing time
