BIKELAND > FORUMS > ZX-14.com > Thread: zx6 clutch springs NEW TOPIC NEW POLL POST REPLY
joel787
posted February 03, 2012 12:00 PM
zx6 clutch springs
I read somewhere that the supersoft clutch springs that mtc and snitz sells are from a zx6 anyone know what year it is?
kawasakijockey
posted February 03, 2012 01:12 PM        Edited By: kawasakijockey on 3 Feb 2012 21:13
Good question. I tried to find that out too. I gave up and bought them from MTC. I have tried them in for fit and never run them, but the Suzuki GS1000-1100 springs fit and are almost as light feeling as the MTC super soft. Dont know if they fit over the shim step on MTC lockups though. Work fine with the Cycle logic.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
joel787
posted February 03, 2012 01:56 PM
Hmm ama go check them out with the pressure plate, did u use all 5 of the soft ones?
kawasakijockey
posted February 03, 2012 02:23 PM
All five. What lockup are you using?
2007 ZX-14
1.38 60ft
9.03 @ 149mph
joel787
posted February 03, 2012 02:26 PM        Edited By: joel787 on 3 Feb 2012 22:30
Mtc 2 stage, would it still be streetable or would i ruin clutches if i run it like that on the street? With all 5 soft..
kawasakijockey
posted February 03, 2012 02:38 PM        Edited By: kawasakijockey on 3 Feb 2012 22:38
No, you wont hurt it but you may have to shim the springs up anyway. I run about 30-35 lbs seat pressure per spring now and I weigh 240-245 suited up. At a factory stack height of 2.140 that would be around .100 shim each spring. Depends on your weight and gearing really.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
joel787
posted February 03, 2012 02:44 PM
Cool, so like 1 shim per arm should work?
kawasakijockey
posted February 03, 2012 02:45 PM
Well, what is your weight, wb, gearing, hp? I might get you pretty close.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
joel787
posted February 03, 2012 02:49 PM
210lbs, about 7 over stock, 17/48, like 185hp
kawasakijockey
posted February 03, 2012 02:54 PM        Edited By: kawasakijockey on 3 Feb 2012 22:55
If its a brand new clutch pack start with .050 shims until the pack is good and worn in then go to .100 shims. Go up or down .025 at a time to get the feel you want, or just throw the lever away if thats whats desired.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
joel787
posted February 03, 2012 02:59 PM
Thanks for the help, how much better my 60s can get?
kawasakijockey
posted February 03, 2012 03:05 PM
I dont see where the regular lockups help 60's as much as they help consistency. If you are in the mid 1.40's already, maybe it wont help at all but if in the 1.50's I can see it helping a good bit. It has more to do with you understanding what is happening when the clutch goes to work so you can tune it. When that is fully understood then getting what you want out of it , within reason, is entirely up to your tuning ability.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
joel787
posted February 03, 2012 03:09 PM
Hmm i see, maybe i just need that racing school then stop buying parts...lol jk thanks man apreciated
kawasakijockey
posted February 03, 2012 03:10 PM
Just pm me if you need help with it.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
quick6
posted February 04, 2012 06:28 AM
if youre hunting for a better 60ft. try playing around with stack heigth. 2.14 is not enough for me. i run mine at 2.17. but i dont have a lock up, only springs and spacers.
2006 zx14, fully dressed and sliding(Charlie Sheen)
kawasakijockey
posted February 04, 2012 06:41 AM
Mine is set up at 2.16 now. Havent really gotten a chance to see any improvement.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
0.28139090538025 seconds processing time
