BIKELAND > FORUMS > ZX-14.com > Thread: Tips or tricks???? NEW TOPIC NEW POLL POST REPLY
bradkong12
posted February 01, 2012 12:00 PM
Tips or tricks????
installn block off plates and spark plugs, Any tips or tricks that will b helpful????
THKS DUDES!!!!!!!!!
bradkong12
posted February 01, 2012 12:26 PM
Use the factory spark plug tool.
bradkong12
posted February 01, 2012 01:03 PM
thks eklip , yeah i remember readn that on here, guess block off plates pretty much no problems
the set i bought didnt come with gaskets, i assume old 1s work fine
i just want to make sure i dont get any leaks
bradkong12
Seno
BANNED FOR LIFE!
posted February 01, 2012 01:20 PM
Pay someone else to do it... ;-)
Compton
posted February 01, 2012 01:21 PM
do the plugs after you do the block off plates, more space to work then.
b.w.
Lsantana954
posted February 01, 2012 02:09 PM
with average size hands and a 3/8 swivel adapter it really isnt too bad. Now with that being said im going by my experience on my '07 that doesnt have the emission control stuff. I am looking at my '12 which came with the emission stuff on it so not looking forward to changing those out.
'12 Gully Blue ZX14
-PCV/Guhl ECU/Blue CT Meg/<0 Alyson Oil/+8 Evil Arm/+1 Rear Sprocket
'07 Acura TL-S
'87 Buick Grand National
Lsantana954
posted February 01, 2012 02:13 PM
also i dont know if or how this effects the bike but according to the service manual it states that the connectors have to be place directly about some marks that are on the valve cover.
'12 Gully Blue ZX14
'07 Acura TL-S
COOTER
posted February 01, 2012 11:48 PM
When you go to pull the sparkplug boot off the plug twist it as you try to pull it up and when reinstalling the plug boot put some grease on the outside of the plug boot and that will help you push it on to the spark plug keep dirt out and make it easier on you the next plug change!!! Good luck and take your time!
bradkong12
posted February 02, 2012 04:25 PM
Got block off plates installed , WOOO tight !!!!!!!
the wire kinda has me worried though???? i read Shanes thread and he said it didnt throw any codes
Shanes is a 06 mine 08 , thinkn there really no difference
I remember seeing some 4sale that said comes with wires so no codes
the set i bought had none
WHERE OR WHAT should i do with wire???????????????
thks dudes , i dont want to put her b together unless shes right
bradkong12
dakota9498
posted February 03, 2012 05:21 AM
Mine is an '08 as well and it doesn't throw any codes, but Shane said that he did notice that is was a bit smoother at low rpm with it connected. Ivan's Performance has a plug that is suppose to fix it but I haven't tried it.
2008 ZX14
dcjens
Wet side of Washington
posted February 03, 2012 07:33 PM
I must be getting lazy. I'd rather drag my nuts over broken glass than to put on block offs AND change plugs! ride that thing
Black 06
0.25175213813782 seconds processing time
