BIKELAND > FORUMS > ZX-14.com > Thread: 2012 ZX14 engine specs NEW TOPIC NEW POLL POST REPLY
APE Jay
posted January 27, 2012 11:15 PM
We now have the specs for the 2012 ZX14 up on our tech site.
http://aperaceparts.com/tech/2012kawasakizx14r.html
http://www.aperaceparts.com/
  Ignore this member    Click here to visit APE Jay's homepage.
kaw now
posted January 27, 2012 11:30 PM
Hayabusa14
posted January 28, 2012 04:17 AM
Check the exhaust system specs.
2012 SE-ZX14R [CT Meg-PC5 with street map-Evil swingarm 64" wheelbase-JRI shock], 2009 GSXR 1000, 2008 B-King, 2007 SE-ZX14 "Brocked out" - 1999 Hayabusa "stage 1" Turbo
06redzx14
posted January 28, 2012 04:27 PM
Anybody know what value that take the cam readings at? ie .040, .050, etc
CajunBoyz
posted January 28, 2012 05:07 PM
I was wondering what Lift are they??? I believe they are the same , & heard someone mention 383/383 ???????
kawa74
posted January 28, 2012 05:42 PM
If you go by Lobe centers it doesn't matter if it is measured at .030, .040, .050 etc. Opening and closing numbers will change as will duration # , but Lobe Center will stay the same .
KHI is measuring Intake at .25 mm, x .03937 inch ( 1 mm = .03937 in) = .0098 in
Take opening 34*, add closing 72* = 106 + 180 = 286 / 2 =143 - 34 ( Allways subtract smaller #) = ......109* lobe center
KHI is measuring Exhaust at .30mm x .03937 in =.0118 in
Exhaust opens 66* add closing 36* = 102 + 180 = 282 / 2 = 141 - 36 = .....105* Lobe Center
"I have never met a man so Ignorant that I coun't Learn from him"..."Galileo"
supra5677
posted January 28, 2012 09:01 PM
The lift is 366 on the intake and exhaust. Also the 207 HP at the crank is a little low. Its more like 213 at the crank without ram air.
supra5677
posted January 28, 2012 09:04 PM
9.3 mm รท 25.4mm is .366 inches...big for a stock bike..
Y2KZX12R
CompetitionCNC.com
posted January 29, 2012 07:29 AM
Its best to check the cam timing at the recommended lift number that the cam grinder says.
Not all cams have symmetrical lobes so the ramps may be different and will change what you measure for cam center lines.
Y2KZX12R
CompetitionCNC.com
gottzx14
posted February 01, 2012 05:08 PM
Does anyone know if the cam base circles are the the same on 14 and 14r's?
OSR Bikes.com, Schnitz Racing Sponsored Rider
Team APE and Team VORTEX rider
justoyz2
Justoyz Racing
posted February 02, 2012 09:22 AM
Jim,
You haven't had your hands on a head yet?
2012 zx14R-blue,2012 zx14R-black, 2014 zx14Trbo, 2011 zx10R, 2007 zx10 Turbo.....
WARBIRD
posted February 02, 2012 02:33 PM
Good question...........
I'd Rather Be Roadracing.
0.38432884216309 seconds processing time
