BIKELAND > FORUMS > ZX-14.com > Thread: Gearing for standing mile? (gen 1) NEW TOPIC NEW POLL POST REPLY
samin
posted January 27, 2012 05:12 PM        Edited By: samin on 28 Jan 2012 01:14
Hi all!
What would be best gearing for standing mile?
Mods: PCV+QS, pipe, speedo healer, (40 shot, not sure about that yet). I have 190/55 rear tire.
Gearing commander is familiar, but I´m not sure about calculating right gearing because of slip (how much?) and what is safe max RPM. Maybe 18/41 or 17/40 to try max 200mph?
I´ve been only couple of times at strip, so all advice's are very welcome. 182 was my best last summer with all stock (but slip-ons), mirrors on etc. That run can be seen *here*
*Who's General Failure and why's he reading my disk?
* ZX-14 ABS -08, Finnish guy ^^
  Ignore this member    Click here to visit samin's homepage.
Rich
Just havin' fun!!
posted January 27, 2012 06:55 PM
I topped out at 197.xxxx on mine with 17 x 40. That was NA and on a 180 x 55 tire. Same day Ali did 199.xxx on my bike with same gearing.
07 Green and Black, How fast is fast?
203 for now. Limited $$ = limited HP.
  Ignore this member    Click here to visit Rich's homepage.
madkawboy
posted January 28, 2012 09:51 AM
I broke 200 with stock gearing at the standing mile. On other days when it is windy it wont pull red line with stock gearing. It will depend a lot on your size and the conditions at the track on that given day as to which gearing you will need to run.
2007 ZX-14
Stock Wheel Base, footshifting, pump gas
5.94 @ 128 mph
1.50 60ft
samin
posted January 28, 2012 10:26 AM
Thanks!
Maybe I should go with 17/40 then?. Or should I wait until I get my bike to Dyno and see curves? How about lowering? How much do you gain top speed with slamming the bike, if any? I was thinking only to remove mirrors and plate.
I would consider myself as average size, 174cm/72kg (5,7/158 US, me thinks).
shiphteey
posted January 28, 2012 11:59 AM
Drop 1 or 2 teeth on the back and see what happens. Don't overgear the bike but you don't want to be on the limiter either.
Your weight ... maybe low/mid 190s n/a? So squeezin a 40 ... maybe -1 or 2 on the back.
Good luck....takes a while to get the hang of it.
A.
Gemini Motorcycles
0.23288297653198 seconds processing time
