BIKELAND > FORUMS > ZX-14.com > Thread: fuel ratio ? NEW TOPIC NEW POLL POST REPLY
joel787
posted January 27, 2012 12:57 PM
fuel ratio ?
Just installed a wideband commander, it reads 13.5-14.0, up to around 6k rpms, havent done any loging or passes yet but what should be a good afr for a stock bike on pump gas? Thanks
06redzx14
posted January 27, 2012 04:04 PM
My wideband reads 1-1.5 leaner than the dyno. I'd compare it to a dyno in your area then go from there. 12.7 on the dyno has worked well for me
joel787
posted January 27, 2012 05:46 PM
Thanks for the reply man, ama start playing with it a bit
posted January 27, 2012 05:59 PM        Edited By: KZScott on 28 Jan 2012 02:00
was it calibrated in fresh air? if its placed properly it should read the same.....
12.8ish at WOT NA
joseph702
posted January 27, 2012 08:15 PM
12.8 pulls great , 13.2 pulls higher on dyno or at least mine did. 12.8 pulled faster down strip so i was very pleased with it.
RICH CRAFT 1
posted January 27, 2012 08:25 PM
12.9 afr is good to go.
Ken
Red 06 ZX14 RR
1badzx12r
posted January 27, 2012 08:33 PM
theres no calibating a DJ WB commander that i know of
joel787
posted January 27, 2012 08:38 PM
For my understanding the higher the # the leaner it is, so should i rev it and adjust or make a pass and adjust to those numbers?
codyc_13
posted January 27, 2012 09:02 PM
Make a pass and adjust from there, free revving isn't going to give you an accurate reading.
8.97 at 149mph
0.21573781967163 seconds processing time
