BIKELAND > FORUMS > ZX-14.com > Thread: 14R cam chain tensioner NEW TOPIC NEW POLL POST REPLY
atldude
Working on it...
posted January 22, 2012 05:41 PM
I was just reading an article in SSB and it mentioned of an updated CCT. Does anyone know if it will possibly fit the 06-11 models?
Seno
BANNED FOR LIFE!
posted January 22, 2012 05:46 PM
Thats a tough one, but I am sure Wheelie, Smokin or Shane will check if you ask nice enough!
zixxer14
Damn that was Quick
posted January 22, 2012 08:40 PM
I just went with the Ape manual tensioner as the stocker was dying. It is a huge improvement as there is no waiting for oil pressure to build, it's just quite as soon as the motor starts. Installation was simple, also it's way cheaper than Kawi's version.
atldude
Working on it...
posted January 22, 2012 09:03 PM
I've been hearing some chatter around 3-4k and the mech that usually works on my bike said its probably cct. I'm still under warranty but that maybe if the new one is better and direct swap it might be a good idea to get one... Once warranty is out and i happen to have probs with it def going to het the manual.
dogg24
posted January 23, 2012 01:37 AM
Could be your tilt over sensor. That is usually about the rpm range they start to chatter and is normal for the 14.
2012 ZX14R SE, Streetmeg, PCV
atldude
Working on it...
posted January 23, 2012 06:19 AM
Nah definitely coming from the engine. When the bike is cold you can barely hear it, starts warming up and starts showing and then once hot it's there. I hate it! :-) Now I am no expert but that's what I was told it is ..
dakota9498
posted January 23, 2012 12:48 PM
That doesn't sound like a cam chain tensioner to me. That noise is usually bad right at start up but gets better once oil pressure is up. If the tensioner was bad it may make it do something different, I am not sure.
2008 ZX14
blue07
posted January 23, 2012 03:41 PM
Possibly IF the spring got weak...might allow that chain to slap anytime?
0.22880911827087 seconds processing time
