BIKELAND > FORUMS > ZX-14.com > Thread: Brocks SingleSlip on 14R ? NEW TOPIC NEW POLL POST REPLY
BobK
2012 ZX14R SE
posted January 22, 2012 04:46 PM
Does anyone know from looking at the 14R exhaust system if it would be possible to have a single slip on set up that would work? A friend of mine just put down 202hp with the stock pipes so I was thinking a single slip on would be cost efficient and probably get good results. Would it need just a different mid pipe?
shawnski
posted January 22, 2012 04:55 PM
Is not going to happen... Either dual slip on or full system.. for a little more money I will get full system... Gives you more performance and less weight.
kaw-rick
posted January 22, 2012 05:02 PM
I just made 1. sucks to be short on cash. but sounds alot better than stock.
shawnski
posted January 22, 2012 05:13 PM
Any pix???
kawasakijockey
posted January 22, 2012 05:23 PM
Not going to work worth a chit. Thats a 1441cc motor you wanna choke back.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
kaw-rick
posted January 22, 2012 05:30 PM
i dont know how to post pics. but yeh i got 1. i can send ya.
shawnski
posted January 22, 2012 05:51 PM
it is ok...no biggy...just curious what you did to it... use image shack if you are familiar.
kaw-rick
posted January 22, 2012 06:11 PM
how could it be any worse than stock mufflers? the exit on 1 side of the header is the same size as smeg midpipe. they just slip mufflers on zx10s all the time.
kawasakijockey
posted January 22, 2012 06:44 PM
It is not the size of the pipe but the flow design that I was getting at.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
kaw-rick
posted January 22, 2012 06:56 PM
i hear you. but cant be any worse than stock. and not tuned to perfection. hell every1s just throwing whole exhausts on right now with no tuning. rickey gadson didnt even use a muffler lol.
fullzx12r
French Guy
posted January 23, 2012 01:26 AM
we wants pics !!!!!
zx-12r 01'
zzr 1400 06'
hayabusa 08'
zzr 1400 12'
posted January 23, 2012 06:53 AM
we wants pics !!!!!
Rick's bike:
BobK
2012 ZX14R SE
posted January 23, 2012 07:15 AM
Rick, do you have any pics of what it looks like under the bike with how you routed and capped everything?
kaw-rick
posted January 23, 2012 10:25 AM
no pics of that. but thats a brocks smeg midpipe clamped on a stock header. i used freeze plug on the other side. i know its crude but have to work for a minute.
SteddyTeddy
posted January 23, 2012 10:31 AM
You freezed plugged the other side??? That has to be choking the chit out of that bike!!!
kaw-rick
posted January 23, 2012 10:39 AM
teddy how do you figure its choked up? the outlet is the same size as a brocks smeg system. that is a brocks smeg midpipe, with a muzzy muffler with no baffling inside. also the muzzy muffler is the same size inlet outlet as a smegaphone.
posted January 23, 2012 10:47 AM        Edited By: Shane661 on 23 Jan 2012 18:49
The bike is beautiful.
The stock header is only 8.8 lbs, so you also ditched a lot of weight. If the outlet is the same as the smeg, I don't see an issue?
SteddyTeddy
posted January 23, 2012 12:30 PM
Guess it all depends on how the gases are routed out the stock header.
dakota9498
posted January 23, 2012 12:36 PM
That is the only problem that I could see, I would think that the exhaust wouldn't be routed very efficiently, might have some reversion problems.
2008 ZX14
fullzx12r
French Guy
posted January 23, 2012 01:35 PM
look OLD SCHOOL ......
zx-12r 01'
zzr 1400 06'
hayabusa 08'
zzr 1400 12'
cls
posted January 23, 2012 04:38 PM
That's the same idea I was after: a single can slip-on w/a modified/designed mid-pipe. It sounds like it oughtta' be cheaper than a full exhaust, PC, and tune/map. I would think a single-sided slip-on would not require a remap or the added cost of the full system. I think some talented someone somwhere should make it happen. Unfortuantely, I have no talent for such things. I do have a little money to spend, though...
Brock
Sponsor
posted January 24, 2012 08:39 AM
We recently tested our dual slip-ons for the 14R... picked up about 3-4 hp peak and 7-8 in the middle. I'm torn the same as always with slip-ons because the part that makes the power is the part you can't see and the performance enthusiast in ME just can't justify the expense vs. gain. But we have plenty of people who are willing to pay $840 retail for a great look and sound, balanced look, easy install, no mapping hassle and not be bothered with minimal power gains because they feel their bike is already fast enough.
Btw: a single sided slip-on will never happen on this bike - at least not from Brock's!
Brock
www.BrocksPerformance.com
  Ignore this member    Click here to visit Brock's homepage.
kaw-rick
posted January 24, 2012 08:53 AM
maybe area p will make 1. lol im not telling any1 what to do. i just fabbed this up bcuz of my lack of funds right now. i will buy a full system when i get right. the stock pipes were hideous and i couldnt take it.
dakota9498
posted January 24, 2012 09:12 AM
Yeah, that seems likely since they didn't make one for the 5 + years that the Gen 1 was out.
2008 ZX14
cls
posted January 24, 2012 05:00 PM
Brock
Yeh, I'm not betting, or waiting, on it. Though it would be great...If you buy the dual slip-ons, the full system is not much more. May as well go all the way by then. It looks like another of your full systems is in the cards. I'm waiting on spring, in any event. And for all you tech guys to get everything figured out first. A thousand thanks for that.
0.24430918693542 seconds processing time
