BIKELAND > FORUMS > ZX-14.com > Thread: DSM-2H shift minder?? NEW TOPIC NEW POLL POST REPLY
CajunBoyz
posted January 22, 2012 06:16 AM
Has anybody used this model,DSM-2H on there ZX-14?? I think it hooks up to 2 of the coils..
dakota9498
posted January 22, 2012 06:34 AM
Why would you use that? Just curious. A Raptor shift light has a launch function and a shift light and is self contained. Uses four wires (speed sensor, coil, 12VDC, ground), all for around $130.
2008 ZX14
BrucerZX14
posted January 22, 2012 08:27 AM        Edited By: BrucerZX14 on 22 Jan 2012 16:27
I've used the DSM-2H before. It does hook up to two coils as the ZX14 ignition system is a wasted spark design. You would hook up to one inside and one outside coil using the supplied Y cable that should be with the unit. The single leg of the Y cable attaches to the green wire for tach signal.
posted January 22, 2012 11:51 AM
I have one and it works perfect!
I tried the msd shift light first, and couldn't get it to work. Msd was of no help. So that's what roger starrette told me to get, he helped me hook it up in about 15 min
CajunBoyz
posted January 22, 2012 12:54 PM
So did you hook up to any 2 particular cylinders??? I want to make sure.. i can't stand to do something & then have to undo it cause something was wired in wrond. Thanks for Everyones help thus far..
BrucerZX14
posted January 22, 2012 02:16 PM
The DMS-2H should have a T101 adapter in the box. One leg of it attaches to the negative lead on one of the inside coils and the other leg attaches to the negative of an outside coil. The green wire from the DMS-2H then attaches to the top leg of the T101 adapter. It doesn't matter which inside or which outside coil. The adapter legs are only so long so hook it to whichever coils it will reach.
posted January 22, 2012 03:50 PM
To be honest, it was at least a year ago... And he did it so fast I don't know, sorry I can't be of help. Maybe if no one chimes in with the right answer I will take the fairing off and see one day this week
CajunBoyz
posted March 28, 2012 08:14 AM
please do, still wanting info for the dyna shift minder to work on the ZX-14.. Don't want to waste alot of time if someone on the 14 went throught the headaches
0.23710918426514 seconds processing time
