BIKELAND > FORUMS > ZX-14.com > Thread: Air shifter porn .. NEW TOPIC NEW POLL POST REPLY
posted January 08, 2012 03:59 PM        Edited By: smokinZX14 on 9 Jan 2012 00:01
Air shifter porn ..
As most of you already know very very well the is no room to mount anything under the seat on a ZX14 ... I didn't want the bottle outside the bike were everyone could see it .. Why ? because every damn time someone sees it they say i'm spraying N20 ..It gets old telling everyone it for the air shifter ... So i'm using 4 oz co2 paint ball bottles that will fit under the seat ... The MPS auto shift box just fits .. it has to be in just the right place or seat will not fit back on the bike ... This is what i came up with ..
Seno
BANNED FOR LIFE!
posted January 08, 2012 04:35 PM
You do nice work, when I get mine will you install it?
Seno
BANNED FOR LIFE!
posted January 08, 2012 04:36 PM
BTW, would a tiger undertail give you more room?
CajunBoyz
posted January 08, 2012 04:44 PM
Is your shifter working correctly now??? If so what was the problem??
posted January 08, 2012 04:59 PM
Air shifter works great ... At this point i didn't have any answers to why the other system failed and cause my running problems in first and second gears..
posted January 08, 2012 05:01 PM
Sure i can do an install for you if you don't mind driving all the way to FL ...lol... I have never used a tiger undertall so i have no clue if it gives you more room or not ..
KAWITOM
My 12R gone but not forgotten
posted January 08, 2012 05:22 PM
No they don't I have one brand new that I don't even think I am gonna use it until something happens to the stock one because the room under the actual gas tank looks like you lose some clearance and thats where I have my solenoids for the spray. Up by the fuses looks like it is about the same clearance only advantage for me is that tiget tail tougher so if you went to low on supsension if you were to squat too much you wouldn't burn through the plastic. Besides I think if you set suspension properly that OEM undertail has plenty of clearance
2012 ZX-14R SE
2002 VULCAN MEAN STREAK (11.41 @ 114 best 1/4)
I BLEED GREEN
Bently
2012 14r In Blue and no Mods!
posted January 08, 2012 06:11 PM
Tom, My suspension is set right And I still rub the tiger when I leave, I say you will rub through you stock one!
KAWITOM
posted January 08, 2012 06:32 PM
That's not what I wanted to hear Brent guess I will have to put it on and find a new spot for the solenoids. thanks party pooper.
2012 ZX-14R SE
I BLEED GREEN
kaw-rick
posted January 08, 2012 06:49 PM
the best place for silenoids is in the battery area. theres room for everything in there after you install a small battery. i had a wet kit on my 06. nothing visible on bike except 2lb bottle.
pazx14rider
posted January 08, 2012 07:50 PM
does anyone know if the tiger undertail will fit under the 2012?
codyc_13
posted January 08, 2012 07:56 PM
It will fit but they relocated the key hole on the 2012 if I recall correctly. It fits except you cave a cutout in the tigertail where the key hole was on the 1st gen.
8.97 at 149mph
Wheelie
Old Man
posted January 08, 2012 07:57 PM
yes it will but they cut the hole for the key on the Gen 1 , all they have to do is not cut it out to make it look better, but Tiger Tail refuses to do that, kinda stupid on their part
wee
Wheelie
Old Man
posted January 08, 2012 08:03 PM        Edited By: Wheelie on 9 Jan 2012 04:09
one pound bottle fit with the oem undertail, note where I moved the rear master cylinder reservoir.
wee
SteddyTeddy
posted January 09, 2012 06:30 AM
Lee your going to have to give me some info on that pressure regulator and bottle hook hp. Got my bike going back together and thinking of switching over to CO2. Will be a couple weeks yet till I'm at the track. Let me know if your going this Wed.
dakota9498
posted January 09, 2012 07:09 AM
+1 that is one of my winter projects.
2008 ZX14
0.29527306556702 seconds processing time
