BIKELAND > FORUMS > ZX-14.com > Thread: Brock's Radial brackets on '12 14R.... Pics NEW TOPIC NEW POLL POST REPLY
VINCE12
Designated Drinker.
posted January 01, 2012 10:11 AM
Brock's radial bracket questions.
The caliper mounting bolts are counter sunk and even with the supplied shims the radial brackets hit the calipers and cause a little damage if you tighten the bolts. When I started to tighten the caliper bolts I noticed it didn't feel right and disassembled and found the clearance issues.
Looks like I would need to tighten quite a bit more to get a good torque. What did you guys do? Tighten all the way and let the radial brackets "clearance" the calipers?
2012 Metallic Spark Black ZX14R
WARBIRD
posted January 01, 2012 10:28 AM
Good eye's Vince........and good pics......
I'd Rather Be Roadracing.
Wheelie
Old Man
posted January 01, 2012 10:38 AM
wee
Wheelie
Old Man
posted January 01, 2012 11:12 AM        Edited By: Wheelie on 1 Jan 2012 19:18
put more washers in between the caliper and the Brocks bracket?
wee
VINCE12
Designated Drinker.
posted January 01, 2012 11:23 AM
put the washers in between the caliper and the Brocks bracket.
wee
That's what I did but the supplied washers are only .040 and it looks like about a .100 thick washer would be needed for clearance.
VINCE12
Designated Drinker.
posted January 01, 2012 11:30 AM
wee
Yeah I put .090 thick washers in and the brackets just barely hit. I'm a little worried about thread engagement. I've always thought you needed at least the diameter of the bolt in thread engagement. Example would be 1/2" bolt needs minimum 1/2" thread engagement?
Wheelie
Old Man
posted January 01, 2012 11:34 AM
I have one washer and they fit good
wee
VINCE12
Designated Drinker.
posted January 01, 2012 11:44 AM
Huh,,, maybe yours came with thicker washers?
With the .090 washers the thread engagement is only 1/4" and the caliper bolts are 3/8" diameter. That's only 4-5 threads holding for each bolt.
VINCE12
Designated Drinker.
posted January 01, 2012 11:46 AM
They would probably be fine but I think I'm gonna get longer bolts and .100 thick shims.
Bigbore4
posted January 01, 2012 10:13 PM
Rule of thumb is 1.5 times diameter for thread engagement
codyc_13
posted January 01, 2012 11:18 PM
Fastenal has longer bolts, should be able to get the washer also..
8.97 at 149mph
BobC
posted January 02, 2012 03:00 AM
On my 06 bike I used four M10 x 70mm Titanium Fine pitch socket cap bolts, (part number TISC1070F from Pro-Bolt) as I thought the threads on the standard caliper bolts would be too short.
I also used a non-permanent thread lock.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
posted January 02, 2012 03:08 AM
Gring a little spot of the brake to give it more clearance
VINCE12
Designated Drinker.
posted January 02, 2012 04:31 AM
Thanks for this info.
GREYHOUNDMOSES
posted January 02, 2012 05:51 AM
Same here on my 09.
It seems the 2012 calipers may be slightly different. Best bet is to measure the length of your stock bolt and add the thickness of the bracket (and any washer you use).
Lucky14
posted January 02, 2012 07:11 AM
Mine are still in the package.
I'll take a look when I get a chance.
Lucky14
posted January 16, 2012 12:41 PM
VINCE12 - Thank you so much for complicating my life!!! J/KI! LOL!
Actually, good catch.
The stock 10mm bolt screws in about 12.5 turns on my 14R.
Add the bracket and the washer(s) and it only catches 5 threads.
That's not even close to "enough" for me, so I ordered the M10 x 70mm Titanium Fine pitch socket cap bolts that BobC referenced (except from Pro-Bolt USA), since I couldn't find them locally.
I'm sure that the stock bolts have been used on many 14's so they *should* work OK.
I just don't like the thought of my calipers breaking loose at 150mph +
posted January 16, 2012 12:43 PM
I shimmed underneath the bracket 5mm and used longer bolts...
VINCE12
Designated Drinker.
posted January 16, 2012 12:53 PM
You're welcome,,,, hahah. I ordered mine from probolt also and I'm still waiting for them.
BIKELAND > FORUMS > ZX-14.com > Thread: Brock\'s Radial brackets on \'12 14R.... Pics NEW TOPIC NEW POLL POST REPLY
0.29383587837219 seconds processing time
