BIKELAND > FORUMS > ZX-14.com > Thread: - My 14R Dyno Results - NEW TOPIC NEW POLL POST REPLY
posted December 19, 2011 02:11 PM        Edited By: Shane661 on 19 Dec 2011 22:15
I finally got the bike on the dyno today. I knew that my "numbers" would be lower than most, because this dyno has proven to be very stingy....-10 hp or so compared to most 250i's I have seen. Still, the dyno operator is great to work with, and I was more interested in relative #'s. Since I have had Racheal's 14, and my own 2011 Busa on this dyno, those would serve as a good baseline...
First, I rode the bike to the dyno in 35 degree temps. Suffice it to say, I was freezing my b@llz off by the time I got there, lol. I used to my cell phone to bring up Wheelie's thread about the coil wire colors, and then we removed the toolkit to find a lead to clip on to.
Getting ready for the big event....
Results soon to come...I have to go through and make some pics off of Winpep7....
Wheelie
Old Man
posted December 19, 2011 02:14 PM
watching, I think orange/ black is the rpm wire.
wee
kawpower
Mr kawasaki 2 you!
posted December 19, 2011 02:15 PM
should of taken of those cans and made a run u woulda been surprized!!
posted December 19, 2011 02:31 PM        Edited By: Shane661 on 19 Dec 2011 22:31
First up was a baseline pull with FACTORY BREAK-IN OIL. Keeping in mind the stingy dyno, this is what we got...
I knew that relatively speaking, on this dyno, this was a strong pull....but I wanted to change the oil right away. Both Lee and Brock had mentioned that the stock oil was going to hold the bike down. I didn't know just how much, but I was about to find out...
Wheelie
Old Man
posted December 19, 2011 02:37 PM
what did your Booza pull on this dyno?
wee
posted December 19, 2011 02:40 PM        Edited By: Shane661 on 19 Dec 2011 22:40
Next I drained the factory oil and I inspected it. Very few shavings were present. However, it was just ugly...it sort of reminded me of this:
It wasn't dirty, it wasn't contaminated....but there was something murky and evil about it....
1badzx12r
posted December 19, 2011 02:42 PM        Edited By: 1badzx12r on 19 Dec 2011 22:44
when i think of dirty oil i think of Kim K.
http://images.search.yahoo.com/search/images?_adv_prop=image&fr=yfp-t-701-s&va=kim+kardashian
MotoCycho
posted December 19, 2011 02:45 PM
Did it look like brains?
posted December 19, 2011 02:47 PM        Edited By: Shane661 on 19 Dec 2011 22:48
Next, I added the Alisyn <<0 WT oil and Petron additive that Brock suggested (and we saw +3 hp on Racheal's bike).
Here is where we stare at the results...
And here are the results...with no other changes...
Lee and Brock were right...new bike in the making...
Next up, comparisons to some other documented bikes on this dyno...
codyc_13
posted December 19, 2011 02:53 PM
That's insane, would have never expected 8 horsepower, and 6 ft-pnds of torque.
8.97 at 149mph
Bently
2012 14r In Blue and no Mods!
posted December 19, 2011 02:54 PM
Over 8 hp from just oil and additive? was that your best run with stock oil and your first run with zero weight?
posted December 19, 2011 02:57 PM        Edited By: Shane661 on 19 Dec 2011 22:58
2nd run with zero wt (1st pull was within .8 hp). Stock oil pull was actually 2nd pull as well, but dyno didn't register on 1st pull. Engine temps comparable. Bike was driven 10 miles on the dyno with the zero wt.
posted December 19, 2011 03:01 PM
Yeah...ugly stuff!
JZX
posted December 19, 2011 03:03 PM
The power curve is exactly the same, just more power all the way thru. The oil works. I remember my tuner telling me about a Gixx 1k that picked up 5hp on his dyno 20 mn later after the oil change-
06 ZX14 65"
Best 1/8 mile 5.68@126.4 on a 1.41 60'
Best 1/4 mile 8.87@152.7 on a 1.47 60'
posted December 19, 2011 03:05 PM
I wasn't joking when i said it felt like a new bike after the oil change and Petron .. I'm happy to see it in print ... ..
Brock
Sponsor
posted December 19, 2011 03:12 PM
Shane,
We saw a 7 horsepower gain through the middle on Christine, our BMW. I always said she had a mixture of sawdust and molasses from the factory... I'm not sure what you would call what your bike had - maybe slurry?!
Brock
www.BrocksPerformance.com
  Ignore this member    Click here to visit Brock's homepage.
posted December 19, 2011 03:13 PM
You were on the money, Lee!
Bently
posted December 19, 2011 03:16 PM
Shane,
Brock
Brock,
Can you say how many passes a guy can run this oil for roughly. I get 300 plus passes from a clutch so I don't fill my oil with clutch crap quick.
posted December 19, 2011 03:19 PM        Edited By: Shane661 on 19 Dec 2011 23:44
Now, many of you probably know that Brock tuned Racheal's '06 14.. What you may not know is that it is the strongest stock motored 14 he has had on his dyno, bar none.
http://www.bikeland.org/board/viewthread.php?FID=27&TID=64599
Well, we have had her bike on the "dream crusher" dyno as well....here are the specs:
2006 ZX-14
Brock's CT Exhaust
Short Velocity Stacks
47mm throttle bodies
No Air Filter
Well-lubed Non o-ring Chain
BST wheel with ceramic bearings
LSR gearing
MR12 Fuel
Guhl Motors Extended Revs ECU
<<0 wt and Petron additive
So, how does this bike compare to the stock 14R on pump gas, same oil, same dyno???
Results coming as soon as I can edit the pic....
Audioboyz
posted December 19, 2011 03:21 PM
Shane;
What oil filter do you use?I'm running Amsoil right now,but I'm changing to Brocks oil after winter.
Craig
2009 Monster ZX-14
Brocks Alienhead,PCV, flys out,LSL Riser kit,-1 front sprocket,43 Vortex rear sprocket,K&amp;N Air Filter, Zero Gravity tall smoked screen,block off plates,175HP 104 torque
Wheelie
Old Man
posted December 19, 2011 03:23 PM
I called Brock, all the oil and additive is backordered.
just kidding lol
wee
posted December 19, 2011 03:25 PM
Shane;
Craig
I have used OEM, Wix, and K&N with good results. I change filters and oil a lot when racing.
Brock
Sponsor
posted December 19, 2011 03:33 PM
Bently,
It would scare you... I have gone over 100 passes on my Diary 14 on <<0 in between changes, and not changed my oil filter for a whole season. I'm busy as hell all the time+ I'm lazy about that stuff ... It's no excuse- but it's reality. BTW, I don't recommend this behavior, but accelerated change intervals are a non-issue as far as I'm concerned. I can't even tell you how much to change it. Let you conscience be your guide, as much as any other oil - but no more.
Brock
FYI: we sell piles of this stuff, hundreds (maybe thousands?) of quarts per year. If guys had problems... EVERYONE would know these days.
posted December 19, 2011 03:37 PM        Edited By: Shane661 on 20 Dec 2011 01:35
Ok, here are the results of Racheal's uber-strong stock motor Gen1 vs...my 14R...
First, both have the good oil..Alisyn <<0 wt oil and Petron additive...
Otherwise, here is the tale of the tape:
Her bike:
2006 ZX-14
PC III
Brock's CT Exhaust
No Air Filter
LSR gearing
MR12 Fuel
Tuned by Brock
My bike:
2012 ZX-14R
Pump Gas
105 miles showing
Results:
Brock can confurm that her's is the strongest stock motored Gen 1 ever on his dyno. The 14R is for real. Next up, results compared to my 2011 Hayabusa that I traded in...
1badzx12r
posted December 19, 2011 03:44 PM
woohoo 2hp
All times are America/Va [ This thread is 5 pages long: 1  2  3  4  5     Next» ] < Previous Thread     Next Thread >
0.28213000297546 seconds processing time
