BIKELAND > FORUMS > ZX-14.com > Thread: Bad Blue track ready ....... :) NEW TOPIC NEW POLL POST REPLY
posted December 08, 2011 05:20 PM        Edited By: smokinZX14 on 9 Dec 2011 02:19
Care package from Brocks came in today ..
Window links ..
41 tooth rear sprocket to calm down the TQ in first gear ..
Not for the track but make the bike not so loud around town .. Brocks Butt plug ..
Brocks Wizbang oil and oil additive ..
I removed the red exhaust tag and replaced it with a black tag..
All that is left to do is get a few more street milles on the bike and change oil.. Then we can all see how slow i can go ..
JZX
posted December 08, 2011 05:24 PM
Good deal, I like the Less then Zero oil, actually had to turn my idle down a hair.
06 ZX14 65"
Best 1/8 mile 5.68@126.4 on a 1.41 60'
Best 1/4 mile 8.87@152.7 on a 1.47 60'
posted December 08, 2011 05:29 PM
I also took a guess at what my rear shock adjustments need to be for the drag strip ... I set my old ZX14 all the way in and backed off a 1/4 of a turn ... Seeing that the new ZX14R is valved a little stuffer ... I set the rebound 1 turn out from seated and the compression 1 and 1/2 out for seated .. I will have to make a few passes and see what it needs but i have to start somewhere ..
Lucky14
Lookin' good!
Great build thread, Shane!
oh, wait .............................
jarhead
posted December 08, 2011 05:30 PM
Nice pile of tools there, the only thing missing is the bfh. I went to a 40 on the rear of my swb 09, does this bike have different gearing from the factory?
posted December 08, 2011 05:31 PM
Nice!
posted December 08, 2011 05:32 PM
Yes the 2012 is 17/42 stock , so i went with 17/41 ... May have to go lower.
posted December 08, 2011 05:41 PM
I'm trying for test and tune next week ... The Dr put my surgery off till Dec 28 ... The Meds he has me on are making me feel pretty good .. Today i did have a little set back and didn't feel so well .. I'm hoping i'll be up to making a few passes next week ... I have to tell you i'm a bit worried... 190+ HP and not being for 6 mos has me a little worried .. So my passes will be easy ones , or very carefully ones ... I'm no damn hero and i have no reason to start being one now ..
Lucky14
posted December 08, 2011 05:46 PM
As much as I want to run mine at stock wb, I don't know if it's worth the effort.
30 more HP than before???
I know you'll do well - just ease into it.
posted December 08, 2011 05:52 PM        Edited By: smokinZX14 on 9 Dec 2011 02:04
Lucky this bike has the same problems as the 2006 ZX14 with flys in .. Look at Wee and Rickys videos .. Everything is fine till 7 grand and the flys open up and then wheel pops up just like the 06 did .. That is why i removed a tooth in rear in hopes it calms it down a bit ..
codyc_13
posted December 08, 2011 06:01 PM
You added a tooth to the rear????
8.97 at 149mph
posted December 08, 2011 06:03 PM
My bad ... I went from a 17/42 to a 17/41
ZX14Mike
posted December 08, 2011 06:13 PM
I'm sure hoping this bike is like the 2006.............pulling the fly's on my 2006 was a worldclass mod.......and best of all it was free!!!!
I'm hoping that piped and tuned with the fly's pulled and 47mm TB's this bike puts out around 210 RWHP
zixxer14
Damn that was Quick
posted December 08, 2011 06:14 PM        Edited By: zixxer14 on 9 Dec 2011 02:15
That's gearing up. Bet that 0w quickens break in a bit.
VINCE12
Designated Drinker.
posted December 08, 2011 06:28 PM
Can't wait for the track results. So the Vortex aluminum sprockets are just for racing or can you run them all the time?
2012 Metallic Spark Black ZX14R
posted December 08, 2011 06:30 PM
Sure i have run them on the street many times ..
0.40330910682678 seconds processing time
