BIKELAND > FORUMS > ZX-14.com > Thread: Auto shift box NEW TOPIC NEW POLL POST REPLY
joel787
posted December 07, 2011 06:34 PM
Auto shift box
is it worth it or is it more trouble than good? i've been thinking about it but i got some bad luck on this stuff
JZX
posted December 07, 2011 07:07 PM
Its great for consistancy, but watch your gearing with it. I used a 10.6 chip and it went thru the traps around a 5 th to 6th gear shift as you can see in my signature, 152 mph, thats only a 26 mph back half. I pulled the chip on a pass that I botched the 60' on and let 5th gear pull too the limiter and my bike went 155.7. You need to use an 11k rpm chip if you want to get the most out of it, or set up your gearing where your in the power thru the traps.
06 ZX14 65"
Best 1/8 mile 5.68@126.4 on a 1.41 60'
Best 1/4 mile 8.87@152.7 on a 1.47 60'
joel787
posted December 08, 2011 01:31 PM
thanks man, what gearings has worked best?
0.22183084487915 seconds processing time
