BIKELAND > FORUMS > ZX-14.com > Thread: cooling issues NEW TOPIC NEW POLL POST REPLY
FIREBRAND74
posted November 15, 2011 06:29 PM
cooling issues
a buddy of mine has a 14, as long as he is riding on the highway he doesn't have any issues.. i know of the zx 10 fender and engine ice, another fan, all of the remedies but that is not the only issue his bike will cut off in stop and go traffic?????im leaning toward the battery as this only happens when the bike is hot...have you seen this and what did you do???Thanks for the advice.....
NINJA12
posted November 16, 2011 03:33 AM
Check his idle speed and map,
Seno
BANNED FOR LIFE!
posted November 16, 2011 05:22 AM
Looking at your cutting off issue: Does he even have a PC3 or PCV installed? What mods are done to the bike? I had a similar issue with a loose battery cable, it would only die when I put on the high beams intermittently, wound up being a loose battery cable.Very vague but I would bet on a loose battery cable, check all your wires, make sure they are fully pushed into the terminals. You did mention quite a few mods for cooling, personally I went with the engine ice and it did help quite a bit.
biggmoinc
posted November 16, 2011 07:51 AM
What u suggest is a good idle rpm n what afr
biggmo@aol.com
ryn0cer0s
Rider for Life
posted November 16, 2011 08:33 AM
Mods are the most common cause of problems. Especially loose connections, and especially on the PC. Bad grounds can cause intermittent problems. Cutting a PC out of the circuit is easy and will let you know if that is the issue. Also, a lean AFR will run hotter.
Battery is easy to check. Take it out and get a dealer to check it for you, or Autozone will even do it.
RYNO
2010 Candy Persimmon Red ZX-14
Brock's Ceramic coated Alien Head full exhaust
PCV, SpeedoHealer, lowered
"Never ride faster than your guardian angel can fly"
samin
posted November 16, 2011 12:11 PM
+1 for loose ground terminal on battery.
mine had similar issues. first i was thinking that cause is TPS zero-throttle calibration, but when electrics eventually died totally after several idle speed stalls (only when hot!) , i spotted actual cause.
br, samin
*Who's General Failure and why's he reading my disk?
* ZX-14 ABS -08, Finnish guy ^^
  Ignore this member    Click here to visit samin's homepage.
FIREBRAND74
posted November 16, 2011 06:13 PM
pipe and pc are the only mods, but ill check the terminals and see... again thanks for response....
0.21519207954407 seconds processing time
