BIKELAND > FORUMS > ZX-14.com > Thread: bike will not stay on NEW TOPIC NEW POLL POST REPLY
busaisbetter
posted November 02, 2011 11:59 AM
I have a 08 zx10r. this morning turned the bike on and warmed it for 3-5 mins and plugged by electric gloves. Within few feet of ridding bike shut down. and after several attempts it fired back up and when ridding on highway it shut back down again but able to restart with clutch.
I put a new air (kn ) filter few months ago and on first day of putting the filter it shut down briefly but since than has had no issues.
Mods: KN air filter. speedohealer
Would like to know whats the problem - air filter, battery or speedohealer.
Outside temp 38F
Wheelie
Old Man
posted November 02, 2011 12:03 PM
Outside temp 38F
your user name says it all.
wee
busaisbetter
posted November 02, 2011 12:13 PM
not this username crap again. ... i post it in zx14 forum because people are more knowledgeable and I can get quick accurate response.
4225 posts - i hope not all by saying "your user name says it all".
Wheelie
Old Man
posted November 02, 2011 12:16 PM
your user name says it all. 4226
wee
posted November 02, 2011 01:25 PM        Edited By: smokinZX14 on 2 Nov 2011 21:26
Try unplugging the speedohealer .. A few people have had problem with them .. If that doesn't do the trick lift up the tank and see if you missed anything while installing the air filter .. On the 08 there are a bunch of grounds under the seat on the frame , check those to see if any are lose ..
Seno
BANNED FOR LIFE!
posted November 02, 2011 06:32 PM
I had a similar issue with HIDs (high beam), when I turned it on the bike would intermittently shut off or lurch. It turned out to be a bad ground. Check your glove wiring for a short or maybe a bad ground.
busaisbetter
posted November 03, 2011 12:09 PM
but wouldn't abnormal ground cause more frequent problems. this is more associated with early cold morning. but i will check under the tank - thanks smokin and seno
miketmmns
posted November 03, 2011 03:06 PM
Put the stock air filter back in it. I had the same problem before
and all we did was change the filter.
Seno
BANNED FOR LIFE!
posted November 03, 2011 06:26 PM
Did you get it fixed? what was it?
busaisbetter
posted November 03, 2011 07:07 PM        Edited By: busaisbetter on 4 Nov 2011 03:09
I plan to work on it this weekend. was your bike also zx10r because my zx14 had race bmc filter and it had no issues.
Seno
BANNED FOR LIFE!
posted November 04, 2011 05:41 AM
I had a zx-10 but had the issue on a 2007 zx-14
miketmmns
posted November 04, 2011 08:06 AM
No it was an 06 636. I had put the kn on it and it wouldn't run when it was cold outside. After I added a pipe and pc it was good with the k&n.
dakota9498
posted November 04, 2011 11:25 AM
I have never had a problem personally, but I have seen several problems pop up from too much oil on the K&N style filters. Which is one of the reasons Brock doesn't recommend them because of the inconsistency it is hard to account for afr. Anyway, it does sort of sound like an air filter oil problem, it would be away worse when it is cold due to the oil gumming up, of course it is hard to diagnose things over the internet..
2008 ZX14
busaisbetter
posted November 04, 2011 02:39 PM
its fixed. it was the ECU FUSE slowly burning away for months. Today after work bike would not start at all and changed the fuse - it started right up. what's the underlying cause?
0.22187185287476 seconds processing time
