BIKELAND > FORUMS > ZX-14.com > Thread: replacing clutch NEW TOPIC NEW POLL POST REPLY
cas15
posted October 27, 2011 08:53 AM
replacing clutch
when the clutch goes on the zx14 do you have to replace the steels and the fibers or could i just change the fibers ? or is it best to change the whole clutch
  Ignore this member    Click here to visit cas15's homepage.
quick6
posted October 27, 2011 09:07 AM
as long as the steels arent warped, i usually change just my fibers
2006 zx14, fully dressed and sliding(Charlie Sheen)
Seno
BANNED FOR LIFE!
posted October 27, 2011 09:35 AM
I went for a CC clutch and have no complaints... Much cheaper than stock and it has held up to lots of abuse.
Aftrer you get fibres check your stack heaight. This is taken from ther maunal
Clutch Plate Assembly Length
Standard: 53.52 ∼ 54.52 mm (2.11 ∼ 2.15 in.)
Hope this helps
cas15
posted October 27, 2011 09:41 AM
how do you know if the steels are warped, the clutch only has about 50 passes so i guess the steels should be good . this started happening after i installed the brock spacers all 5 i guess the extra pressure finish the clutch off
cas15
posted October 27, 2011 09:44 AM
Hope this helps
thanks im gonna look into it
dakota9498
posted October 27, 2011 09:53 AM        Edited By: dakota9498 on 27 Oct 2011 17:54
Extra pressure shouldn't "finish off a clutch".
Also, for what its worth, if you drag race stay away from the Cycle Concepts and just go OEM. They are not really that much more expensive, I ordered a set from Adam's last month for $190 I think.
2008 ZX14
NINJA12
posted October 27, 2011 10:17 AM
What problems did you have with the cycle concept clutch?
Was planning on getting them next. Always heard they were better than stock.
dakota9498
posted October 27, 2011 11:04 AM
Not better than stock, I got less passes out of them than I did the OEM units. As far as performance though, they were about the same.
2008 ZX14
zixxer14
Damn that was Quick
posted October 27, 2011 11:26 AM
Lay the steels on a flat surface( glass plate works great ) & look for raised areas. They should be flat all around.
Bently
2012 14r In Blue and no Mods!
posted October 27, 2011 11:41 AM
opposite for all of us here more passes from the cc, clutches over oem. both 14's and busa's. my buddy holds the record in our group over 700 passes on his cc clutch no lock up
dakota9498
posted October 27, 2011 11:42 AM
What kind of 60 foot times?
2008 ZX14
Wheelie
Old Man
posted October 27, 2011 11:43 AM
my buddy put that pak in his Booza got less runs than oem, he's back to oem
wee
Bently
posted October 27, 2011 12:02 PM
his busa 64 inches and 1.42 60 foots runs 8.90 on motor 8.60's spraying. my 14 1.35 to 1.38 60 foots. it's all riding style we have 5 bikes running cc paks and all outlast oem hands down.
cas15
posted October 27, 2011 12:41 PM
thanks 190 aint bad for the whole set
cas15
posted October 27, 2011 12:43 PM
thanks
BLK ICE
Cycle Concept clutch packs work better & last longer than OEM for me. 1.3x 60 feet.
posted October 27, 2011 03:58 PM
Cycle concepts clutch has been fine for ms as well. I put it in last November and I haven't had a bit of trouble out of it. Cut consistant 1.37-1.38 this weekend making 3 back to back to back passes multiple times throughout the day.
I would buy another one for sure.
Bently
posted October 27, 2011 05:29 PM
My buddy who has the 700 runs on his made 31 passes last saturday from 12 to 4 7 of them using the nos. runs mobil one car oil 5-20
Seno
BANNED FOR LIFE!
posted October 28, 2011 03:05 AM
I launch the shit out of my 14 and seems to work better for me than OEM .. Err used to launch the shit out of my 14, dealer owns it now ;-(
cas15
posted October 28, 2011 08:26 AM
when you replace the clutch is their a special way to install the fibers and steels i know the steaks have a cut to them does the cut go in or out thanks
posted October 30, 2011 05:21 AM
round edge in
0.22452402114868 seconds processing time
