BIKELAND > FORUMS > ZX-14.com > Thread: 16/43 NEW TOPIC NEW POLL POST REPLY
cas15
posted October 23, 2011 10:40 AM
16/43
hey guy need some advice for the track on a launch rpm for 16/43 gearing .
  Ignore this member    Click here to visit cas15's homepage.
posted October 23, 2011 10:47 AM
We need more info. Wheelbase, lowered, suspension, etc
cas15
posted October 23, 2011 11:10 AM
wheelbase is at 66,lowered,stock shock adjusted i had 16/45 gearing etc is 9.50 but want to try 16/43
posted October 23, 2011 03:09 PM
All my numbers came off 66" wb bike. I wasn't as consistant when I was at 16/43 as I am at 16/48. So my advice wouldn't be very helpful.
cas15
posted October 23, 2011 03:15 PM
ok thanks for the effort tho
Quarter Pounder
with Cheese
posted October 23, 2011 03:41 PM
seat time is your best friend. Get out there and see what rpms work best for you and your riding style. Everyone is different.
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
cas15
posted October 23, 2011 03:52 PM
nice numbers did you remove the flys on ur 08 i also have a 08 but not sure if you need to remove on the 08
3000psi and falling
posted October 23, 2011 04:18 PM        Edited By: 3000psi and falling on 24 Oct 2011 00:22
If you leave the flys in, you can go with an ecu unleashed tune and pick up big mid rpm hp. My tuner talked me into it, this is how it works, the ecu is programed to open the flys at a much lower rpm (just like pulling them) then at mid rpm they start to close creating a Venturi effect speeding up the incoming air or somthing (i dont know the details on how this part works) boosting hp.
Quarter Pounder
with Cheese
posted October 23, 2011 04:42 PM        Edited By: Quarter Pounder on 24 Oct 2011 00:43
thanks...I did remove the fly's..but would I would go with an ECU reflash and leave them in nowadays. This was not an option at the time when I did mine.
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
cas15
posted October 23, 2011 05:58 PM
hmm not a bad idea im gonna look into it. so i do gain power if i get them pull or an unleased tune.
Lucky14
posted October 24, 2011 03:29 AM
Are you talking about a 14 or was that a Busa???
I didn't think anyone ever successfully cracked the 14 ECU???
edszx14
posted October 24, 2011 04:18 PM
I had my ECU reflashed by Dynotronics in Texas and it picked up 7 HP.
Ed
Seno
BANNED FOR LIFE!
posted October 24, 2011 05:27 PM
How much did Dynotronics charge for the reflash?
3000psi and falling
posted October 24, 2011 06:03 PM
My local tuner offers ecu unleashed for the genII 14's. If you re install the flys they can be manipulated to give a nice mid rpm hp boost.
edszx14
posted October 25, 2011 05:26 PM
Dynotronics charged me $450.00 for the ZX14 ECU reflashed. He raised the RPM limiter 450 rpms, removed the top end speed restriction, removed the timing retard in the first four gears, and turned the radiator cooling fan on 10 degrees earlier. Here is a link to their website: http://www.dynotronicstuning.com/. I hope this helps.
Ed
cas15
posted October 25, 2011 05:55 PM
good info
JSmooth
posted November 02, 2011 01:14 AM
I tried 67" but I am getting alot of tire spin on launch I am not sure if the 67" is causing it or the tires I am using? Bike seems to light in the rear
posted November 02, 2011 06:36 AM
What kind of tire? How is your rear suspension set up? Your suspension can play a big role in getting the tire to hook.
0.21803689002991 seconds processing time
