BIKELAND > FORUMS > ZX-14.com > Thread: 14R Drain Plug - Anyone notice??? NEW TOPIC NEW POLL POST REPLY
Lucky14
posted October 22, 2011 12:55 PM
Extra ground clearance - from the factory!!!
Kawasaki IS listening!!!
ZX14Mike
posted October 22, 2011 01:15 PM
Good post!!!!!!!!!!!!..................I was wondering about the drain plug clearance and meant to ask that question last week!!!!!
Rajun Cajun
posted October 22, 2011 02:01 PM
That is great! Now the little guard that used to be there will not get knocked off!
Candy Thunder Blue 2006 ZX-14, +1 rear, RoaringToyz blocks, windscreen spikes! (VERY SHARP! DO NOT TOUCH!!!!)
Time lost can not be retrieved! Its not dumb to ask questions. Rajun Cajun
acc454
posted October 22, 2011 02:48 PM
Noticeable difference on header pipe diameter too. I'm excited to see some exhaust system testing.
Audioboyz
posted October 22, 2011 03:14 PM
Those pipes look huge!I still would have to dump all the cats and those monsterous cans.
Will still wait at least a year maybe 2.
Craig
2009 Monster ZX-14
Brocks Alienhead,PCV, flys out,LSL Riser kit,-1 front sprocket,43 Vortex rear sprocket,K&N Air Filter, Zero Gravity tall smoked screen,block off plates,175HP 104 torque
Seno
BANNED FOR LIFE!
posted October 22, 2011 03:25 PM
Looks like we gained an extra inch! Sweet!
oldkawboy
posted October 22, 2011 04:11 PM
Good eye Lucky!!
That is some more good news.
Dan
frEEk
posted October 22, 2011 06:08 PM
Good eye Lucky!
Audioboyz, you'll prolly wanna lose the headers too, simply because it sounds like they are steel, thus heavy as well.
Audioboyz
posted October 22, 2011 06:13 PM
My Brocks S/S are light.But I have the stock one in my garage.It's hard to believe how heavy it is.
Craig
2009 Monster ZX-14
zixxer14
Damn that was Quick
posted October 22, 2011 08:22 PM        Edited By: zixxer14 on 23 Oct 2011 04:24
I missed the plug move but caught the missing idle adjuster, No more manual control? I wonder if the pans are interchangable?
Beondwacko
posted October 23, 2011 04:28 AM
I also just noticed something,,,,,, where's the speedo sensor? It's no longer on the primary cover. I guess it uses the traction control sensor on one of the wheels. No more speedo healer needed ??
posted October 23, 2011 05:42 AM
this bike is looking better and better
posted October 23, 2011 06:11 AM
It's not knocking the guard off that's a problem, the problem is knocking the oil plug into the pan.
justoyz2
Justoyz Racing
posted October 23, 2011 06:16 AM
I am only speculating here, but I am sure they used the same technology from the '11 zx10.
The entire undercarage is like a straight line. The oil pan design is almost like a flat oil pan, the engine cases houses the oil. The internal pick up is very long.
The Gen 1 oil pan was a mishap waiting to happen. Kawi knew of the flawed design; this is why there is a horizontal baffle plate to prevent the drain plug from entering the engine case in the event of a bottoming situation. I burst my oil pan doing freeway riding. I hit a dip in the road, the bike bottomed out and knowcked the drain plug loose. I fixed it on the side of the road with JB Weld (Stick). I was able to make it home.
Not only the oil pan, but look at the exhaust, if you view a '11 full pic, look how low the stock exhaust hangs. Everything is tucked underneath the fairing. In the pic above it doesn't show.
2012 zx14R-blue,2012 zx14R-black, 2014 zx14Trbo, 2011 zx10R, 2007 zx10 Turbo.....
thutch26
thutch26
posted October 23, 2011 07:22 AM
what about the injectors? bigger? 2 sets? any1?
justoyz2
Justoyz Racing
posted October 23, 2011 11:55 AM
I am not sure on the injectors size, however I offer this:
"Injectors deliver lateral spray at a 20-degree angle to disperse the finely atomized fuel over a wide area
- Fine-atomizing injectors produce a 75-micron droplet size"
I would suggest that they replaced the current model with something a lil better and with more capabilities to work with the larger engine. I don't recall them mentioning anything about a larger fuel pump, so larger injectors would have to handle additional fuel demand.
posted October 23, 2011 12:16 PM
this is the same as 2010 specs i just looked up
0.2492790222168 seconds processing time
