BIKELAND > FORUMS > ZX-14.com > Thread: Need guidance for exhaust change? NEW TOPIC NEW POLL POST REPLY
FOTIS
posted September 14, 2011 04:48 PM
OK I decided to go with a full system for my 2008 ZX-14.
I will be getting a K&N filter, full exhaust system and power commander.
Questions.
Will a PC III work or is a PC V required?
and more importantly which exhaust for max HP gain and weight loss?
Obviously the more economical versions are more appealing. A package price would be great if anyone knows of a place who does this......
Thank you in advance!
We are what we repeatedly do. Excellence, then, is not an act but a habit.” --Aristotle
posted September 14, 2011 04:57 PM        Edited By: smokinZX14 on 15 Sep 2011 01:00
Brocks CT and. PVC from Brock loaded with his Race map .. Call him for a package price..
Audioboyz
posted September 14, 2011 08:25 PM
Or the Brock Alienhead which I have and love.
Craig
2009 Monster ZX-14
Brocks Alienhead,PCV, flys out,LSL Riser kit,-1 front sprocket,43 Vortex rear sprocket,K&N Air Filter, Zero Gravity tall smoked screen,block off plates,175HP 104 torque
FOTIS
posted September 14, 2011 10:07 PM
Are these for track use only? My use will be limited to street use.
Audioboyz
posted September 14, 2011 11:08 PM
I never been to the track just street use.I use the track map with no flies and 89 octane.It works fine.Brock has spent hundreds of hours on the dyno and at the track to make your job easier.Mine is a little loud but I like it;I want to get it dynoed just to see what it is.Not that it matters.It runs very strong from 3-10050.
Craig
2009 Monster ZX-14
posted September 15, 2011 01:43 AM
All aftermarket exhaust is "track use only".
Usually the shorter pipes are a little louder than the ones with a longer baffle.
Yes a pcIII will work.
Which one is best bang for your buck? They are all within a few hp, so it's up to you. But, brocks does have the best customer support and map support which can save you a lot of money on a dyno.
FOTIS
posted September 15, 2011 01:25 PM
thank you
0.24368715286255 seconds processing time
