BIKELAND > FORUMS > ZX-14.com > Thread: XZ-14's and exaust change? NEW TOPIC NEW POLL POST REPLY
FOTIS
posted August 28, 2011 12:22 PM
Kinda new on the ZX-14 thing but had a 2005 Busa very modded before I sold it.
Anyway looking to install a full exhaust system.
Am I correct to assume that any such modification will require a PC Commander and remapping? Thank you all in advance.
We are what we repeatedly do. Excellence, then, is not an act but a habit.” --Aristotle
trganey
posted August 28, 2011 12:32 PM
You are correct. Hopefully in the near future there will be a cable and software available to flash the ecu so there won't be a need for the PC or Bazzaz but for now there isn't unless you want to send your ecu to someone else to have them do it. Then if you make more changes and need to re-map you'd have to send it off again. Not very productive for folks that like to work on their own stuff. jes my .o2
ryn0cer0s
Rider for Life
posted August 28, 2011 01:11 PM
A PC may not be REQUIRED, but it is a good idea since it will change the way your bike runs. Also, there are other fuel management systems than the PC. I am not really familiar with all of them, but I know that there are add-ons for some of them. Quick shift, as well as fuel management. I have seen the Bazzaz Z FI TC has traction control, but not sure if that works on the ZX14. It is not available through the Bazzaz website, but I found it on other sites.
Does anyone have info on the TC for a ZX14?
RYNO
2010 Candy Persimmon Red ZX-14
Brock's Ceramic coated Alien Head full exhaust
PCV, SpeedoHealer, lowered
"Never ride faster than your guardian angel can fly"
Audioboyz
posted August 28, 2011 01:29 PM
I'm thinking about adding the PC ignition module for my PCV.I've got a muzzy ignition wheel but I would rather be able to change the advance electronically in case I get it dyno tuned.
Craig
2009 Monster ZX-14
Brocks Alienhead,PCV, flys out,LSL Riser kit,-1 front sprocket,43 Vortex rear sprocket,K&N Air Filter, Zero Gravity tall smoked screen,block off plates,175HP 104 torque
FOTIS
posted August 28, 2011 01:52 PM
Thank you gentlemen!
LeoVinceZX14
Thankfully...its paid for...
posted August 29, 2011 12:43 PM
TC for a ZX 14..
Fotis:
Congrats on the 14 purchase,welcome to the board and good luck with all your planned mods. Just chiming in for the TC question raised since I just read your post. Not looking to hijack your thread bro.
rynOcerOs:
As I understand it, the Bazzaz TC system does NOT work with the 14 though of course the fueling module does. Apparently a ECU issue at least for a 14. I don't pretend to know the technical fine points of it all. Took the explanation of this from my tuner (KWS in North Myrtle Beach, SC).
Leo
'12 14R SE
PC V
Custom map
BMC filter
Leo Vince 4-2-1 w/ carbon can
Sato frame sliders
Supersprox 42T
Cox radiator guard
DID 530 X-ring chain.
BIKELAND > FORUMS > ZX-14.com > Thread: XZ-14\'s and exaust change? NEW TOPIC NEW POLL POST REPLY
0.23739385604858 seconds processing time
