BIKELAND > FORUMS > ZX-14.com > Thread: NOS mini controller wiring question NEW TOPIC NEW POLL POST REPLY
edszx14
posted August 07, 2011 02:32 PM
Hello. I am trying to wire up a NOS mini controller and don't understand exactly what the yellow (output) wire from the controller and the green wire (tach) from the controller actually get attached to. The instructions just state what the wire function is but not where to attach them.As anyone used this controller and how did you wire it up. I am only wiring up one nitrous solenoid and its driving me nuts. Any help is greatly appreciated.
Ed
06redzx14
posted August 07, 2011 08:03 PM
The green wire is used for window switch when connected to the negative side of a coil. The yellow wire is a grounded output. I used it to switch maps when I was delaying my nos nos I use it to activate my timing retard.
edszx14
posted August 08, 2011 03:11 AM
Thanks for the info. Which wire (color and number ) on the ECU connector did you connect the yellow wire to..
Thanks again.
Ed
06redzx14
posted August 08, 2011 05:36 AM
the yellow wire is to be connected to relays that trigger things like map switching or timing boxes
edszx14
posted August 08, 2011 04:47 PM
Cool. Thanks again for your help. It is greatly appreciated.
Ed
0.21483612060547 seconds processing time
