BIKELAND > FORUMS > ZX-14.com > Thread: Smog removal question NEW TOPIC NEW POLL POST REPLY
3000psi and falling
posted August 05, 2011 12:18 PM
I bought block off plates for my upcoming dyno tune, Qusetion, the wire you disconnect from the assembly, do you just leave it unpluged? Ive also read there is concern for crank case ventalation after doing this..
joel787
posted August 05, 2011 12:48 PM
Yeah those plugs dont matter, i put a crank breather filter from autozone, it leaks some other then that works fine
posted August 05, 2011 01:14 PM
Why are you waiting to do it before you get your bike dyno'd? I didn't think it affected the a/f ratio.
3000psi and falling
posted August 05, 2011 01:24 PM
I could be mistaken, I thought it did by pupming air into the exhaust to help burn off fuel in the exhaust and that gave false AFR readings to your tuner. Oh well, there still going on since I bought them and to free up the area for plug changes and what not.
Where do I install a pcv valve (if needed?)
posted August 05, 2011 01:41 PM
I'm Not real sure about that, just what I've heard. I was curious.
1badzx12r
posted August 05, 2011 01:50 PM        Edited By: 1badzx12r on 5 Aug 2011 21:50
you don't need no PCV valve ..and you are correct on the air being pulled thru the exhaust .. just put the plates on and your set ..
FIREBRAND74
posted August 05, 2011 05:10 PM
what are the benefits of doing this ????
1badzx12r
posted August 05, 2011 06:17 PM
less junk to work around when doing repairs or servicing plugs ..also if your datalogging A/F'S its a must
FIREBRAND74
posted August 05, 2011 11:04 PM
thank you sir.....
Y2KZX12R
CompetitionCNC.com
posted August 06, 2011 05:37 AM
+1
Y2KZX12R
CompetitionCNC.com
bradkong12
posted August 06, 2011 12:52 PM
any HP gains from this mod??????
i thought they just stopd decel pop
bradkong12
johnbull
posted August 09, 2011 08:19 AM
Dont go on the dyno without blocking them off or you'll be wasting your money and getting a very inaccurate AFR reading!
John Bul Racing. Malta.
0.2355489730835 seconds processing time
