Insaneroller
posted July 29, 2011 11:25 AM
Edited By: Insaneroller on 29 Jul 2011 19:47
My 2007 Euro Version ZZR-1400
Apologies if this has been discussed before. I have the following setup, in terms of performance:
- tsukigi cannon gp full system
- bmc filter
- flies removed
- speedo healer
- Muzzy drag clutch
- pc3 usb (WITH THE STANDARD DYNOJET EURO MAP FROM THEIR SITE)
1stly:
my issue here is that i'm using the normal tsukigi full system rather than the map for tsukigi cannon gp full system. I'm guessing thats still Ok. now i've gone ahead & got these:
- muzzy 15mm velovity stacks
- boneville pro box
- 43 vortex
- Dynojet quickshifter
NOW: - Wont I require to map it properly now, specially with the velocity stacks??? Forgot to mention that there are no dynos available here...
PLEASE HELP
2007, ZZR1400, flies out, Bonneville pro, BMC, Tsukigi Cannon GP full system, pc3, Muzzy velocity stacks, Muzzy drag clutch kit etc etc etc
oldkawboy
posted July 29, 2011 06:23 PM
On my ZX12R very little mapping was needed when I installed velocity stacks, not sure on the 14's but I'm guessing it'll be okay. Shane would probably be your best bet for that info, maybe he'll chime in if he sees this thread.
The important thing is that you have a flies out map. The bike will run very, very lean with just a standard map for an exhaust.
Dan
Insaneroller
posted July 30, 2011 01:00 AM
yes mate at least the flies out map is there so that was a relief. the US maps which were killer as per my setup, unfortunately made my 14 to start bogging out & ultimately switch off. Thats is when i realized this US & Euro ecu issue. Now i cant find any one with this setup or this exhaust system for accurate mapping. Hoping to get some help here,
@Shane, please help.
Insaneroller
posted July 31, 2011 09:24 PM
so where are the pros who can help me out. come on guys!!!
Insaneroller
posted September 07, 2011 01:36 PM
Another strange issue... Installed the pc3 Dynojet quick shifter, it's shifting @ 4k rpm at present. It started bogging out at times when I was clutch shifting just below 4k rpm... Dam confused. Then the boneville pro box, had instructions as per the usa zx14 version ecu & connecting wires... Which is different in the euro version... Frustrating day...
posted September 07, 2011 01:59 PM
do some searches for european maps. the ecu programming may be different. there are tons of flies out maps here for every system. i use brocks maps supplied with the pipe. perhaps tsukigi supports their product as well. good luck!
Insaneroller
posted September 07, 2011 07:51 PM
I've actually given up searching for euro maps buddy... Been searching for tsukigi cannon support for ages but the only ppl who respond is tsukigi usa
Now I'm not sure what's the issue with the quickshifter & why my 14 starts bogging out... Muzzy is atleast helping me for the boneville pro box installation...
bradkong12
posted September 08, 2011 01:49 PM
lol muzzy is helpn u!!!!!!!
what iv read is muzzys CS sux
ask the brock guys lol
bradkong12
bradkong12
fishn no bites
bradkong12
bradkong12
posted September 08, 2011 01:53 PM
LOL JJ
bradkong12
posted September 08, 2011 01:56 PM
Edited By: Shane661 on 8 Sep 2011 21:57
You will not need to alter the map with those velocity stacks. However, if you want to get the most out of your mods you need to get a data logger and tune it under load. That will be more accurate than a dyno anyway. A dyno and a good tuner can get you very much in the ballpark, but to fine tune the bike you need a logger.
Insaneroller
posted September 08, 2011 02:05 PM
Thanks Shane but I ain't that technically sound to tune it that way...
Hehehehe, I've been dying to install a Brocks dual full system, unfortunately they don't have a euro map nor does Dynojet UK have one. So dead end there...
Insaneroller
posted September 11, 2011 06:46 AM
http://www.flickr.com/photos/24701580@N04/6136601256/in/photostream
http://www.flickr.com/photos/24701580@N04/6136054039/in/photostream/
Insaneroller
posted November 26, 2011 06:32 AM
Hey guys I'm having trouble location the right replacement for my 14's T (stem/cone). Either that's the wrong work in using or there's not much other than the bearings etc kit available by all balls racing??? Have been told that bad roads, speeds of 300kmph, wheelies have weakened my Front T section, which is to be more precise, located below my defected GPR damper. Any suggestions & advice on what's the keyword I need to search this part ??? Pls help
Insaneroller
posted February 20, 2012 10:11 PM
our sunday rides...
http://www.youtube.com/watch?v=0pb7Y_NpCP8
http://www.youtube.com/watch?v=OUn_oal9Yts
http://www.youtube.com/watch?v=9ej73J28JdY
Insaneroller
posted March 06, 2012 10:17 PM
some street fun...
http://www.youtube.com/watch?v=QVwvZE-zQTM
http://www.youtube.com/watch?v=cSpOLBqGPEA
http://www.youtube.com/watch?v=gtqp-XdlPWg
