BIKELAND > FORUMS > ZX-14.com > Thread: 06 fuel pump NEW TOPIC NEW POLL POST REPLY
starchild
posted July 03, 2011 06:22 PM
06 fuel pump
hey guys need a fuel pump but do not want an 06..heres the problem starts up fine runs good at rpm lower 6000 but coming out the hole she sputters nose dives runs like shit never makes it down the track . i did pull out the pick up screen and it was filthy plenty of crap..but the problem did not stop bike still ran like sh*t, dont think its electrical pulled pcv ran stock ecu could it be ecu? is there a bosch or other fuel pump? if i need a stock want a 08 or better fuel pump. any help or suggestions dead in the water here. thanks
jay
kingtramp
posted July 03, 2011 06:55 PM
08 pump is physcially smaller then 06/07 pump, before you spend time on changing pump , check fuel pressure, should be 43psi at idle. consider getting injectors cleaned if fuel pressure checks good. Also make sure battery connections are good connections/corrosion free at terminals.
starchild
posted July 03, 2011 08:30 PM
will do thanks for the help
jay
zxbob
posted July 04, 2011 05:43 AM
It aint the fuel pump - check your PCV ground and fuel presure as previously mentioned.
Bob
starchild
posted July 04, 2011 07:35 AM
thanks Bob going through the whole bike today pcv ground it would really suck to find out i loss races i should have won due to a ground wire
jay
starchild
posted July 04, 2011 07:38 AM
Bob i did run the bike without pcv...ran it stock same problem bypassed pcv no change
jay
0.24031710624695 seconds processing time
