BIKELAND > FORUMS > ZX-14.com > Thread: PCV Autotune ? NEW TOPIC NEW POLL POST REPLY
vic
posted May 28, 2011 06:57 PM
PCV Autotune ?
I seem to feel my A/F mixture off idle to 5000RPM is running to lean. When I first start my bike when it's cold, letting the bike worm up about a minute as the ECM is still on the choke mode. When I rev the throttle the engine response is excellent . Soon as the choke turns off, I twist the throttle , the engine is sluggish.
If I install the power commander autotune module will it solve my A/F mixture problem ?
If I remove the flies, will autotune correct the A/F mixture?
Any input would be appreciated
Vic
0.2713189125061 seconds processing time
