BIKELAND > FORUMS > ZX-14.com > Thread: idle question NEW TOPIC NEW POLL POST REPLY
head_zx14ninja
2010 xz14
posted May 27, 2011 06:19 AM
idle question
Hey guys,
What should my 2010 14 be running at on idle (after the cold start turns off).
I'm just curious.... Does a certain settin make easier for daily commutes around town??
Martin
“One thing leads to another”? Not always. Sometimes one thing leads to the same thing. Ask an addict.
GREYHOUNDMOSES
posted May 27, 2011 09:42 AM
RTFM
GREYHOUNDMOSES
posted May 27, 2011 09:43 AM
Sorry Martin
Idle Speed
Standard: 1 100 ±50 r/min (rpm)
FastestBusaAround
I eat Fish...
posted May 28, 2011 07:19 AM
I have mine running at around 1400 or so...
At 1100 with PCIII and pipes...I find it not as responsive and it has a tendency to stall from time to time...but I'm also running a 4 degree timing advance.
FYYFF!!!
billeason
posted May 28, 2011 05:43 PM
If you have a gauge on it watch your oil psi on a hot summer day ,stop and go traffic at idle' and you'll see why its a good idea to keep it 13-1400 rpm's hot .
bill eason
head_zx14ninja
2010 xz14
posted May 28, 2011 06:35 PM
i have mine on 1200 atm, i had it on 1300 but when i changed the gearing (-1 front) i dropped it to 1200.
Cjuni
posted June 12, 2011 07:01 AM
All I have an 07 completely stock zx14 & its almost @ 1500, is that ok also, once I put it in 1st it clunks pretty hard could this be part of the problem??
Thanks in Advance
Cjuni
dogg24
posted June 12, 2011 07:10 AM
Thanks in Advance
Cjuni
That is normal. I know on mine though it tends to be lesss noticeable after the bike has warmed up more.
2012 ZX14R SE, Streetmeg, PCV
Cjuni
posted June 12, 2011 09:42 AM
I see, mine is that once it's warmed up which is why I ask, also the manual says 1050 - 1100?
posted June 13, 2011 07:58 AM
1100-1200 is where i have mine. the higher you set it the more clunk you will have putting it in gear.
Cjuni
posted June 13, 2011 05:56 PM
Thanks that's seems to be what I'm readin, I will look into lower it and trying it out & go from there.....thanks again all!
head_zx14ninja
2010 xz14
posted June 14, 2011 04:35 AM
1500 is a little too high i think... it would be clunking pretty hard also....
TEC1
posted June 14, 2011 11:35 AM
seems to be fine with the factory recomended 1100 rpm
Cjuni
posted June 15, 2011 04:52 PM
Set to 1200 to 1300, much better now thanks again!
0.34772801399231 seconds processing time
