BIKELAND > FORUMS > ZX-14.com > Thread: ZX-14 Stock Pistons and cams makes 211 hp NEW TOPIC NEW POLL POST REPLY
Y2KZX12R
CompetitionCNC.com
posted May 25, 2011 09:46 AM
Just thought you guys might like to see this. Here's an example of what a zx14 motor can do with all factory parts in it. It has stock pistons, crank, rods, cams, valves, springs, etc. in it. It does have our 47mm throttle bodies and our latest version of our Super Sport head on it with degreed cams.
This was dynoed before and after on the same dyno with mr12 fuel.
Y2KZX12R
CompetitionCNC.com
nicks14
posted May 25, 2011 11:06 AM
Nice!!!!!
hellraiser
dakota9498
posted May 25, 2011 11:15 AM
Wow, that is impressive. What's the compression ratio if it is running on MR12?
2008 ZX14
Y2KZX12R
CompetitionCNC.com
posted May 25, 2011 11:18 AM
13.2
Y2KZX12R
CompetitionCNC.com
dakota9498
posted May 25, 2011 11:31 AM
Nice, those are the mods I have been planning for this winter. I will definitely be getting in touch with you towards the end of the season.
2008 ZX14
oldkawboy
posted May 25, 2011 12:01 PM
Jim,
With the weight of the bike and rider, do you see any problem running MR12 (since the Motor Octane is 87) in the 14 with 13.2CR in LSR events?
That's some great numbers and with a bone stock bottom end it should be very, very reliable.
Dan
osti33
posted May 25, 2011 01:01 PM
Wow!!
Great job Jim.
01smokes
posted May 25, 2011 01:08 PM
What Does it make on pump??
PayPal, vigilart22@yahoo.com
Email, artvgl@yahoo.com
posted May 25, 2011 01:18 PM
Wow that red A/F line was pig rich .. The blue A/F line is too lean , with ram air that thing is going to be deep into the 14s A/F ..
I like the hp numbers , Jims SS head makes great power and add MR12 it gets even better !
posted May 25, 2011 01:20 PM
I think 203 to 204 hp on pump gas would be in reach ..
Y2KZX12R
CompetitionCNC.com
posted May 25, 2011 02:20 PM
Jim,
Dan
Dan, the R+M/2 octane rating is typically about 4-5 points higher. About a 91 or 92 octane rating, or about equal to pump super. That number that is what you are used to seeing at the pump. You can run 13.5 to 1 and pump super in any of these modern shallow chamber engines.
So I don't see a problem at all.
Y2KZX12R
CompetitionCNC.com
Y2KZX12R
CompetitionCNC.com
posted May 25, 2011 02:24 PM
We have had feed back of 198-202 on shell 92 from several customers. The shell 92 seems to make the best power from the pump.
Y2KZX12R
CompetitionCNC.com
Y2KZX12R
CompetitionCNC.com
posted May 25, 2011 02:32 PM
Lee, the map sensor will add fuel to compensate for any changes in manifold pressure.
I have data logged at over 200 mph and compared the data to the dyno a/f ratio and the computer compensates for ram air pressure. The a/f ratio stays consistent. But that was on a 2000 zx12r. I'd imagine the zx14 does the same.
The tests in the graph above were done with mr12 fuel.....
Y2KZX12R
CompetitionCNC.com
oldkawboy
posted May 25, 2011 04:47 PM
Thanks Jim for the info.
Also, am I right in assuming that the SS headwork you perform leaves the ports untouched?
Just a valve job and milling the head?
Dan
knecum
posted May 25, 2011 06:22 PM
Nice job Jim!! looks like your a/f is 13.5 min and up to 14.0 up top..just saying!! Thts tuning for power there...
engines on a bench
posted May 25, 2011 07:30 PM
Jim Brock sets up around 12.9 on the dyno for his Drag map and his Maxton Map is 3 % richer than that for a reason .. I'm just saying ..
Ratfink
posted May 25, 2011 08:35 PM
you wouldnt mind sending me a pm of this price wise otd if i brought my bike up to you guys would you
madnessracing
Vmax and Busa Beater
posted May 25, 2011 10:53 PM
Ok Jim those are some bad ass numbers but I'd like to know the numbers this bikes are putting at the track too.
Shorty's Performance
Team Madness Racing
Y2KZX12R
CompetitionCNC.com
posted May 26, 2011 03:25 AM
Dan
Dan, yes, an AMA SS legal head does not have any touching up of the ports. Its not allowed. However if the customer doesnt need to be legal for SS racing then we can do some hand blending of the valve bowls and rubber manifolds.
Steve, Brian tuned it and I'm not sure where they left the a/f ratio. I personally like 12.7 - 12.9 or so even thou 13.1 seems to make the best dyno power.
I'll have the actual run files soon so I can open them and get a good look.
Y2KZX12R
CompetitionCNC.com
Y2KZX12R
CompetitionCNC.com
posted May 26, 2011 03:31 AM
Lee, what did you guys pickup for mph with the ss head?
Y2KZX12R
CompetitionCNC.com
posted May 26, 2011 06:29 AM        Edited By: smokinZX14 on 26 May 2011 14:30
Jim i'm sorry to say this but Jesse sold the head before i had a chance to install it ..Jesse got completely out of racing.. The only head we got to test was one i had my head guy do a little work on .. It was milled 20 thou and had a little work done under the intake seat .. Nothing was done to the exhaust side .. Jesse bike went for 171 HP to 184 HP same day same dyno on the same map .. A gain of 13 HP made us pretty happy with so little work done to the head..
thutch26
thutch26
posted May 26, 2011 12:53 PM
Nice... OSR made similar #'s on a stocker they did awhile back... I am a believer!!! Jim... what does your 2mill make with head,bodies,cams?
madnessracing
posted May 26, 2011 12:57 PM
I wanna know how fast this bikes are going or just tell me how many tenths faster it has been from best stock motor runs.
Team Madness Racing
Y2KZX12R
CompetitionCNC.com
posted May 27, 2011 03:58 AM
Depends on compression, fuel, pipe etc.
We have had our cnc ported head and cam packages make well over 230 on 1417cc.
It really depends if you want to set it on kill, drag race only, or run pump gas on the street.
Y2KZX12R
CompetitionCNC.com
01smokes
posted May 27, 2011 07:22 AM
Ok how many MPH will or should this pick up in a 1/4 mile if I were to have it done to my bike?
0.96798181533813 seconds processing time
