BIKELAND > FORUMS > ZX-14.com > Thread: Pressure testing the Airbox- Turbo related NEW TOPIC NEW POLL POST REPLY
Stu64
posted May 15, 2011 07:35 AM
I had a boost leak on my bike when i took it in for tuning. I made up a rubber plug with a air connection and regulator to check the airbox.
Put it in the incoming turbo tube to airbox
Found a good leak at the second hole on the back of the steering stem.
My question is now that leak is fixed,how much pressure should the airbox hold?
The throttle bodies are not air tight so pressure goes into the combustion chambers and past any open valves.
posted May 15, 2011 07:53 AM        Edited By: Shane661 on 15 May 2011 16:01
I bet you could seal it to test it. Perhaps some aluminum duct tape sealing the velocity stack area. Especially if you remove the stacks, that should be easy.
But, aside from that, these boxes can hold at least 20 psi...if properly sealed...just based on the fact that LeonidasZX14 has run about that on his Jones Performance bike.
What kind of stacks are you using, and how is the box sealed? What kit? One thing with the 14 that seems nice is that with good stacks, and frame sealing, you wouldn't have the problem of lifting the plenum under high boost like you can on other bikes.
Stu64
posted May 15, 2011 08:09 AM
I can get almost 7psi on the boost gauge before i get what sounds like air coming out the exhaust.
I using stock stacks and there doesnt seem to be any air coming from there.
I just had them out yesterday and they fit tight as can be.
posted May 15, 2011 08:13 AM
I am not sure how much it will hold with stock stacks. I can tell you that the Factory Pro stacks seal much better than the oem, even for an NA app.
Can you block off the exhaust??
1badzx12r
posted May 15, 2011 08:17 AM
theres the hole on the bottom by the neck that you plugged in your test .. but also theres a hole going into the neck that will leak pass the steering bearings.. when you got the stock air filter cover open you can see it hiding behind bracing .. that stock airfilter cover even when replaced to a billet oring type is a bitch to seal even with silcone
Stu64
posted May 15, 2011 08:44 AM
Got both sealed,the bottom one with screw in it wasn't leaking,the upper one was,sealed it no more air through the stem.
But still not sure if box is sealed cause air gets past the throttle plates.
bigwil
06 zx 14 turbo stage 3
posted May 15, 2011 09:01 AM
go with the big cc racing or the ones from cris jones or oriaint express now makes the same set of volocity stacks that seal better . the factory pros laek at 10 to 12 psi
Photobucket
Photobucket
bigwil// going fast aint easy so turbo it
bigwil
posted May 15, 2011 09:07 AM
stu64 did you seal the 2 holes by the batttery box 1 is the drain tube from the frame think the other one was a bolt hole
1badzx12r
posted May 15, 2011 09:30 AM        Edited By: 1badzx12r on 15 May 2011 17:32
crank case vent (but there is a bolt in this tube in the battery box) and the others the drain on the foot shifter side .. i did like shane said but i stuffed rags into the throttle bodies them taped it .. then soaped the airbox ..to my amazement them stock volecity stacks held to 15lbs ..and when they did leak it was from the rubber to frame meeting joint ..
i only run 8 lbs of boost tho
Stu64
posted May 15, 2011 09:34 AM
Yep those had sealed from the beginning. As far as the stacks go, i'm only looking to see maybe 10 psi max,more likely around 8.5psi.
I think the airbox itself is sealed up now,just want to make sure there isn't anything i over looked before putting this bike back together.
bigwil
posted May 15, 2011 09:40 AM
are you doing 2 wheelspeed next week
Stu64
posted May 15, 2011 09:44 AM
Nope, don't know how much time i will get for Byron this year, i have to get my bike dialed in first and then see what class i'll fit in.
Was thinking 8.90 if i turn my shift points down a little.
bigwil
posted May 15, 2011 09:56 AM
im going to run the 8.90 shifting early and only running 10 t0 12 lbs of boost on the controler feeding it slowly wish they would do the 8.50 class they were talking about to many bikes in the class makes it harder for the faster bikes to mutch sandbagging
Dale
posted May 16, 2011 05:23 PM
Bigwii: I was not aware those factory pro had sealing problems. It makes me curious about your Turbo stage 3 set up. Would like to know more if you don't mind sharing.
2007 Kawasaki Ninja ZX-14 Special Edition Turbocharged
bigwil
posted May 18, 2011 02:48 PM
what would you lk to no dale
Oz Booster
posted May 18, 2011 03:24 PM
Probably the same things as me
What turbo kit or parts combination??
engine management?
engine mods ??
how is it working for you, what do you like or dislike about it
Maybe i should start a thread asking the same things of other turbo guys
I have the Cycle concept part kit from Shane and intend taking it a bit further than the original design
Planning gt3071 turbo, external wastegate, Would love to intercool it but its not real intercooler friendly, may just water inj
Thinking i may have to Sandwich plate the main airbox holes for high boost
I have an Aem Fic piggyback , they can be troubled by "electrical noise" on the busa, may be better on the zx .
Looking at pistons,rods,oil mods, studs,have some .070 gaskets coming, clutch springs
Have i missed anything that NEEDS doing ?
Nice tips on the velocity stacks
bigwil
posted May 18, 2011 04:52 PM
its a hahns kit and no its not the old super 16 gs he used to makeits a prtotype he did on my bike its a custom Turbonetics 88mm T6,ina t5 housing Ceramic Ball Bearing he never ededed up making the kits im rining power comander multi hub and ignithin m. wego 3 datta loger ,ams 1000 boost controller /mtc 3 stge lookup mcintosh 12 over arm he also cut my forks 2.5 inchs litz revalved shock w/busa spring cp pistins corello rods ,ape valve springs and retainers full port, removed ballencer .oil feed . bigg cc volocity stacks walbro xtern fuel pump cut pan still runing stock injectors making just over 370 hp best time so far is 821 @186 im stipp playing with it im sure ill get it in the 7s this year brian from winn racing does most of the work at win-racing.com its by far no cris jone set up by for but im working with what i got dont have a lot of time or money to mess with that mutch it been on the bench for a year finly got a bug up my ass and stated messing whith it again and seeing how my last 2 kids grad/ thisthis year isu and western i mite have some money againim sure i mised alot but you get it
sorry stu didnt mean to jack your thread
bigwil
posted May 18, 2011 05:04 PM
spell check ill type slower
Oz Booster
posted May 18, 2011 07:19 PM
Thats one hell of a nice kit, with lots more potential in there yet , 17-18 psi for the 370hp ??
Thanks for sharing
1badvespa1400cc
power junkie
posted May 19, 2011 04:58 AM
Cyclogics kit upgraded to a 20g,external muzzy fuel kit and rail,stock rods,pistons,wideband,boost gauge,external tial wastegate,tial blow off,cyclelogics lockup,300 on 110 oct.oh and osr oil cooler block off.
Just another foeteen!!!!!
Dale
posted May 19, 2011 06:31 PM
Very impressive Bigwil!
Stu64
posted May 21, 2011 03:26 PM
Well the leak is fixed and BOV works good!! Problem is now i took it for a ride down the freeway(short bursts) and saw 10 psi on the gauge,do i leave it,or take a few shims out of the waste gate? Was hoping to keep it under 9 psi.
Dale
posted May 22, 2011 07:29 PM
Honestly, unless your detonating I would leave it. Not sure what kit your using. It would great to see some pics of your set up.
Stu64
posted May 24, 2011 09:11 AM
Ok, another question for those of you running a boost controller, where do you have it mounted? I have a ams-500 . Thanks...Stu.
1badzx12r
posted May 24, 2011 06:31 PM
man i try running the least amout of boost i can get away with in this warm weather ..i bracket and index race and as long as i can run that number .. who is there to impress . this winter is another story ..
0.23696112632751 seconds processing time
