BIKELAND > FORUMS > ZX-14.com > Thread: Fuel level gauge NEW TOPIC NEW POLL POST REPLY
1badvespa1400cc
power junkie
posted May 14, 2011 07:27 AM
Fuel level gauge
Installed a external fuel pump and no longer have the internal pump.Here's my issue gas gauge no longer work's,no big deal there but I wonder if the miles left readout is still accurate?
Just another foeteen!!!!!
1badzx12r
posted May 14, 2011 07:41 AM        Edited By: 1badzx12r on 14 May 2011 15:42
YEAP EVERYTHING IS STILL WORKING .. JUST YOU GET A FLASHING LOW FUEL .. SORRY ON CAPS.. i had to fix mine because the 1st time you run low on fuel .. bad things happen
1badvespa1400cc
power junkie
posted May 16, 2011 06:09 AM
How did you fix it?
1badzx12r
posted May 16, 2011 07:10 AM
i put a 1k ohm resistor in line on the fuel low fuel sensor and mounted the sensor under the seat
1badzx12r
posted May 16, 2011 07:13 AM
i couldn't find the thread i had but this will help http://www.bikeland.org/board/viewthread.php?FID=27&TID=48812
1badvespa1400cc
power junkie
posted May 16, 2011 10:16 AM
Thanks guys i will give that a try.
1badvespa1400cc
power junkie
posted May 17, 2011 06:32 AM
so the miles left till empty is still correct?
1badzx12r
posted May 17, 2011 08:24 AM        Edited By: 1badzx12r on 17 May 2011 16:25
i have an 06 model ..when my flashed nothing else is viewable or at least i never look .. mine stays on voltage ... but i can tell you what happens when you run it low and suck air on the launch ..
GREYHOUNDMOSES
posted May 17, 2011 11:36 AM
Nobody likes to carry more fuel up the strip than needed but I've always erred on the side of caution because I didn't know what would happen.
I take it that sucking air wrecks more than just the launch!!!
1badzx12r
posted May 17, 2011 11:41 AM        Edited By: 1badzx12r on 17 May 2011 19:41
yes it does ..it put a hole in 1 piston and damage the other 3 TURBO BIKE .. the problem was the track didn't have any race gas .. caused i'd put my 2 gallons in it .. but i wanted to make that 1 more pass after the low fuel warning had been on for 1 pass already ..
0.23590493202209 seconds processing time
