BIKELAND > FORUMS > ZX-14.com > Thread: Gearing info needed NEW TOPIC NEW POLL POST REPLY
FAST Z14
posted May 09, 2011 10:27 PM
Gearing info needed
I am running a 16 sprocket at the front and standard at the back on my 14,the acceleration is great but the bike will only run up to a 301km/h,if I drop 1 tooth at the back will this still be better than standard gearing acceleration with a higher top speed,has anybody got this gearing on a 14,I use my bike for street riding only.
FOLY HUCK
01smokes
posted May 09, 2011 10:31 PM
How fast do you wanna go?
PayPal, vigilart22@yahoo.com
Email, artvgl@yahoo.com
FAST Z14
posted May 09, 2011 10:46 PM
If I can run a 308Km/h with a little better acceleration than standard gearing it will be great
FOLY HUCK
BobC
posted May 10, 2011 12:24 AM        Edited By: BobC on 10 May 2011 08:41
You don't say how you are measuring your speed or if your bike has enough power to pull max rpm but :-
16/40 should give you 317 kph before the engine rev-limiter. If you only get 301 kph it looks as if you are running into the speed limiter which operates when the ECU reads 300 kph or 186 mph, whatever the gearing. So you need to de-restrict it first perhaps?
If you want to keep the 16 tooth engine sprocket and gear it 16/41 you will hit the engine rev-limiter at 308 kph. If the bike is de-restricted and it can't pull that gearing to maximum rpm then it's not making enough power.
Remember, if you de-restrict with a Speedo Healer you do it by making the speedo under-read so you'll need another way of measuring speed. GPS or the timing gear at the track for instance.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
GERRIE01
posted May 10, 2011 01:43 AM
on this subject i also want to ask...on my 14 im running stock gearing...on the gps i run a constant 324km/h !! just for interest sake what type of speed will i be doing with a 42 at the back ? my bike has a pc3 with flowed head and cams full muzzy pipe and bmc filter and quick shifter ! im also from south africa and im almost 2000ft above sea level !!
to be second means you
are the first loser
BobC
posted May 10, 2011 03:28 AM        Edited By: BobC on 10 May 2011 12:36
If you could pull the same rpm with 17/42 you would be doing 316km/h. The engine rev-limiter should operate at 320km/h, so you're possibly there - within 1% or so.
Stock wheelbase
posted May 10, 2011 10:28 AM
http://www.gearingcommander.com
posted May 10, 2011 04:59 PM
Why would you want to go that fast on the street?
Audioboyz
posted May 10, 2011 05:29 PM
I just got off the gearingcommander site.I was running 16/43 last year but the gas mileage suffered and the real problem I couldn't keep the front end on the ground.I got 16/41 now and I'm going to get the GPS out to see how far it's off.I never had my bike over a true 165 mph and that felt scary.Pa roads are choppy and trying to see the end of the sraight is a rush.Some of them go up a hill or a slight bend.My back tire has a few thousand mi left and the next tire will be a 190/55/17 so I'll have to change the Speedohealer again.
Craig
2009 Monster ZX-14
Brocks Alienhead,PCV, flys out,LSL Riser kit,-1 front sprocket,43 Vortex rear sprocket,K&N Air Filter, Zero Gravity tall smoked screen,block off plates,175HP 104 torque
0.26436996459961 seconds processing time
