BIKELAND > FORUMS > ZX-14.com > Thread: Can some one post a pic of the speedo nut that been ground NEW TOPIC NEW POLL POST REPLY
01smokes
posted May 08, 2011 08:59 PM
I'm away from a computer and searching off my phone and cant seam to find anything, and was wondering if some one can bump a thread with a pic or just post some pics up for me thanks guys
PayPal, vigilart22@yahoo.com
Email, artvgl@yahoo.com
posted May 09, 2011 01:41 AM
It's the nut that holds your front sprocket on.
ninjaboy311
posted May 09, 2011 08:54 PM
01smokes
posted May 09, 2011 09:20 PM
Thank you so much I appreciate it.
BlackMagic14
posted May 10, 2011 07:46 PM
Doesn't this affect the "miles" you put on your bike as well as your tach and in turn my autoshift?
CraigChrist
BAWLS
posted May 10, 2011 07:56 PM
It won't affect your shifts since your autoshift should be going off of your coil wire and not your speedo signal.
60ft-------1.42
1/8th------5.97
mph-------119
ksig419
posted May 10, 2011 10:24 PM
what does grinding one side off do? Is there a magnet on each of the four sides that the sensor picks up on and when you grind one off then it reads different?
Halvefast
posted May 11, 2011 09:45 AM
the speedo pick-up reads each of the 4 corners,
remove 1 it reads 25% lower, remove 2 it reads 50% lower doesn't affect rpms at all
ECTA Ohio Mile 195.132mph
Sheard
posted May 11, 2011 08:08 PM
Will this mess up the rpm on factory tach? Can I do this on stock bike?
ksig419
posted May 11, 2011 10:32 PM
halvefast said that it would not affect RPM's at all so I assume yes
ninjaboy311
posted May 14, 2011 11:26 AM
Does not affect RPM's. This is only the speedometer pick-up. Will slow down the mileage readings on the odometer, which is a good thing when its time to sell it.
01smokes
posted May 14, 2011 01:10 PM
Just finished it works great.
ksig419
posted May 14, 2011 02:20 PM
where is this nut located at?
01smokes
posted May 14, 2011 05:34 PM
My nuts are in my pants..
No its the sprocket nut.
3000psi and falling
posted May 14, 2011 06:08 PM
HA!
08green
posted May 14, 2011 06:15 PM
lol
2004 ZX10
2008 ZX14
posted May 14, 2011 06:48 PM
Read post above. It's the nut that holds on the front sprocket.
JSmooth
posted May 15, 2011 06:58 AM
This may be a stupid question but here goes, has anyone shaved down all the corners on the nut? If so does it offer even better results? Yes I see where it was posted 1 corner and 2 corners but I want to know what is the effect of all 4 being done?
GREYHOUNDMOSES
posted May 15, 2011 07:46 AM
Strictly speaking, this doesn't "de-restrict" the bike, it raises the speed at which the bike is restricted.
With two lobes removed the bike can go 372mph before the restrictor cuts in.
If you want to go faster than that you'll have to buy a V-Max.
They don't have any lobes on the sprocket nut.
0.28615117073059 seconds processing time
