BIKELAND > FORUMS > ZX-14.com > Thread: Air shifter pressure? NEW TOPIC NEW POLL POST REPLY
gilberjj
Friend of Fast
posted April 16, 2011 05:31 PM
How many psi should I use for my low pressure air shifter?
How low can I run it to make sure I get at least 4-5 shifts. Will 100 psi work?
dakota9498
posted April 16, 2011 05:40 PM
I always put 120psi in mine. I go through traps at the top of 5th and make another shift just to coast in 6th.
2008 ZX14
gilberjj
Friend of Fast
posted April 16, 2011 05:42 PM
I've heard that most use 120, but I was wondering if I could do 100 psi.
02zx12rbob
posted April 16, 2011 05:46 PM
125 psi 1lb.bottle. Last long time, never misses unless spinning.
posted April 16, 2011 05:54 PM
I run 140
johnsonzx14
posted April 16, 2011 06:10 PM
do any of you run your air in the swingarm?
dakota9498
posted April 16, 2011 07:12 PM
I don't think so, if I run 120 and make 4 or 5 shifts it takes me below 100 and if I forget to refill (not that it has ever happened or anything), it will make one shift maybe. So starting out with 100 and after a shift or two it takes you down below 90psi I don't think that it would work.
I don't, I am running extensions on a stock arm. My air tank is on the ledge between the forks and the bottle is in my left fairing (a la KawasakiJockey).
2008 ZX14
posted April 16, 2011 08:26 PM
my regulator is set at 150psi as is dads.
Bently
2012 14r In Blue and no Mods!
posted April 17, 2011 04:38 AM
150 for me as well as the rest of my group.
johnsonzx14
posted April 17, 2011 05:50 AM
any of you have the muzzy shifter..I have had it for a long time, just never put it on..If so , how was the install? pretty easy? Im going to put mine on next weekend when I get my swingarm
kawasakijockey
posted April 17, 2011 06:27 AM
If you put the solenoid directly on the actuator you can shift at 100 psi, but I would personally shoot for 125-140 psi.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
kawasakijockey
posted April 17, 2011 06:29 AM
I have it on my bike with over 5000 shifts now. The install wasnt hard to understand because the instructions were pretty thorough with pictures.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
0.33080101013184 seconds processing time
