BIKELAND > FORUMS > ZX-14.com > Thread: clutche GONE!! HELP NEW TOPIC NEW POLL POST REPLY
bradkong12
posted April 11, 2011 12:17 PM
clutche GONE!! HELP
guessn clutch is gone , 6th gear 3000rpm give WOT and slipn bad , then did samething 2nd and 3rd
08SE 15,000miles hard miles 50passes at strip, is this normal to need clutch allready
THKS 4 ANY
bradkong12
bradkong12
posted April 11, 2011 12:20 PM
what do i need 2 replace, brands prices ext
i hav never replaced 1 or seen it done, HELP PLS!!!!
bradkong12
posted April 11, 2011 12:58 PM
Call dewayne at cycle concepts. Good guy and great clutch pack!
bradkong12
posted April 11, 2011 01:56 PM
thks i thought i read that some where on here but i couldn't find
should replace springs 2??? do i need any special tools???
around how 4 the cycle concepts kit???
sry never did 1 or seen it done
did read Shanes thread helpd alot,
bradkong12
bradkong12
posted April 11, 2011 02:03 PM
i hav a front sprocket on back order from schnits, i guess will hav them send me
a set of clutch picks instead, hopn b only tool i need
bradkong12
Wheelie
Old Man
posted April 11, 2011 02:14 PM
Dusty, guys are getting 15,000-22,000 miles out of a oem clutch and you want them to buy a different clutch? LOL
wee
bradkong12
posted April 11, 2011 02:17 PM
???? my bikes has 15,000miles hard miles 50 passes on strip
should the stock clutch b gone, Is this normal ??????
bradkong12
bradkong12
posted April 11, 2011 02:22 PM
think muzzy has 4 around 195dol , think OEM around same price
i 4 sure want put 1 n that will last as long as stock did
bradkong12
Wheelie
Old Man
15,000 "hard" miles? that is allot of miles out of a clutch, normal.
wee
kaw-rick
posted April 11, 2011 02:23 PM
every1 rides different, some people slip clutch more than others. gearing, weight, other factors weigh in. i used stock clutches in my zx14. put a new 1 in there and go.
posted April 11, 2011 04:51 PM
wee
I've had his clutch for 6 months with no problems. I am taking it out of the bike before I go to the track again to measure the stack height. I'm pleased with it, as many other people have been.
I don't think I've seen one negative post about his clutches.
Show me the negative post about his clutch packs from legit people and I will keep my thought to myself.
kawiman
posted April 11, 2011 05:53 PM
+1 on the drag pack
1badzx12r
posted April 11, 2011 05:58 PM
if this clutch has never been into ..then to get you by for a little while .. take the cover off ...then take the 5 bolts and springs out.. take the pressure plate off .. then align the 1st fiber with the rest... reinstall everything.... cause whats happen is you 1st fiber has hit the wear limiter and is slipping like the factory has design it to do ..
bradkong12
posted April 12, 2011 11:08 AM
thks guys , lookn like drag pak,
Should i replace or put brock springs while im n her, heavier springs????????
thks again
bradkong12
Bently
2012 14r In Blue and no Mods!
posted April 12, 2011 11:31 AM
+1 on the drag pack
+2 on drag pack. only thing I use once stock clutch is toast.
posted April 12, 2011 11:50 AM
I think this is the same drag pack under a different name ..Offered by APE..
http://aperaceparts.com/mailers/trackingclutches.html
Bently
posted April 12, 2011 06:17 PM
You could be right smokin, if it is it's well worth the 156.00
Flame On
Fuel Air & Spark
posted April 12, 2011 06:32 PM
My Drag pak clutch is working great for daily riding . If I was going to drag race I would get a heaver spring kit the drag pak ones in the kit I bought felt the same as the OEM spring tension.
77 RD 400
80 GS1000 GT
06 ZX14
0.24818801879883 seconds processing time
