BIKELAND > FORUMS > ZX-14.com > Thread: turbo questions NEW TOPIC NEW POLL POST REPLY
ksig419
posted April 10, 2011 09:53 AM
turbo questions
Hey guys well since my bike is going to be down for a little while because I will be having shoulder surgery and buying/painting new pastic - I was wondering some info on Turboing my 14. I was wondering if anyone sells just the manifold. also wondering what all do I have to do to the internals to mae sure everything is on the safe side. I dont want to spend a ton of money on it but I also dont want to be a complete cheap skate on it either. I have looked around a little bit and cant seem to find anything on a step by step process. Like the Hayabusas does the 1400 have an Aluminum Airbox that replaces the existing one? The kits that I have seen do not show anything over top of the throttle bodies. Just wondering a few things and your help is appreciated
-KEN-
posted April 10, 2011 11:04 AM
are you under the impression that your bike has a plastic air box now?
gilberjj
Friend of Fast
posted April 10, 2011 11:27 AM
Buy shanes partial kit in the classifieds. It's the basis for my kit.
ksig419
posted April 10, 2011 11:33 AM        Edited By: ksig419 on 10 Apr 2011 19:34
yes I am. I have never dug into a 1400 before. frankly this is my first KAW bike. I knew that my Busa had a plastic airbox so I thought that they would be the same way.
gilberjj
Friend of Fast
posted April 10, 2011 11:56 AM
The frame is the airbox. No need for a plenum on the zx14, but you do have to block off all possible leaks. Buy shanes kit and you will be far better off the. Putting your own together from scratch.
dakota9498
posted April 10, 2011 02:20 PM
I think that sold on Psychobike.
2008 ZX14
ksig419
posted April 10, 2011 02:42 PM
if his kit was the one minus the turbo then it was sold. I was very excited when I seen it then WHAM I seen the word sold. I was heart broken lol. Anyone else make a header only? I have been looking with no success. Might just have to have one made custom, I had a guy quote me 600-800 to do the job but the hing is that he is only a fabricator/welder with no motorcycle experience. I figure that all he has to do it get all 4 cylinders to run into one collector smoothly. {shouldershrug}
posted April 10, 2011 04:45 PM
http://www.google.ca/imgres?imgurl=http://images.motorcycleparts2u.com/parts-pics/mp2u900666-2009-kawasaki-zx14-motorcycle-frame.jpg&imgrefurl=http://motorcycleparts2u.com/2006-2009-kawasaki-ninja-zx14/motorcycle-frames/mp2u900666-2009-kawasaki-zx14-motorcycle-frame.htm&usg=__nXY5qCBMA-CkSH3bnX_4_vevgIE=&h=300&w=400&sz=27&hl=en&start=4&zoom=1&um=1&itbs=1&tbnid=epCP6thvQ3FvZM:&tbnh=93&tbnw=124&prev=/images%3Fq%3Dzx14%2Bframe%26um%3D1%26hl%3Den%26safe%3Doff%26sa%3DN%26rlz%3D1T4DACA_enCA255CA258%26tbm%3Disch&ei=3U6iTd_uMaOV0QGD9rGIBQ
ksig419
posted April 10, 2011 05:38 PM
no worky on linky
dakota9498
posted April 10, 2011 05:47 PM
no worky on linky
Try cut and paste...
or for the lazy ones.
2008 ZX14
Big_T112
posted April 10, 2011 06:21 PM
I just bought the header from Muzzy. Ebay Chinesse copy of a garrett turbo. Make sure you weld or expoxy the big hole up by the steering neck. not really that hard but more work than doing a Busa.
Big_T112
posted April 10, 2011 06:25 PM
You might not have your pressure plate seated correctly.
ksig419
posted April 10, 2011 06:41 PM
Thanks dakota I tried to cut and paste the first link and it wouldn't work.. tha link explained a lot. What's the pricing on the muzzy header alone. All I seen was the header. Andturbo combo with the wastegatr for like 3200.
ksig419
posted April 11, 2011 10:01 AM
Actually I just called muzzy and it wasn't a bad price at all. Only 599 which is a lot cheaper than my 600-800 quote. And no wait time.
gilberjj
Friend of Fast
posted April 11, 2011 12:51 PM
I drilled and tapped it. Then I put a bolt in it. It's the lowest spot in the air box, so that way if any oil or fluid accumulates, I can easily drain it.
gilberjj
Friend of Fast
posted April 11, 2011 01:06 PM
I doubt he has any more partial kits left, but give Mark a call
got his number from the ebay ad where Shane and I both got our partial turbo kits, his number is...
(941) 286-8240
I think I got mine for $525 shipped.
Good luck!
ksig419
posted April 11, 2011 01:19 PM
just got off fthe phone with MArk and he said that he has none of the partial turbo kits left for the 14 but he does have some sort of odd and end pieces left and that he will be home in 10 days and give me a call about what all he has for sale that I might need. thanks a lot guys for the help/info.
0.26892495155334 seconds processing time
