BIKELAND > FORUMS > ZX-14.com > Thread: Bonding Carbon Fibre. NEW TOPIC NEW POLL POST REPLY
GREYHOUNDMOSES
posted March 22, 2011 01:16 PM
I'm looking to fit some switches in my carbon fibre ram air covers.
I've got some scraps of carbon fibre and want to fit a small square behind where the switches
will go to stiffen / strenghthen the cover panel.
Any advise on what to use or avoid for sticking the two pieces of carbon?
gilberjj
Friend of Fast
posted March 22, 2011 03:19 PM
Gorilla Glue???
BobC
posted March 23, 2011 03:24 AM        Edited By: BobC on 23 Mar 2011 15:22
Use Polyester Resin, same stuff that's used for glass fibre. Saturate the carbon mattting with the resin and it should bond to the back of the ram air cover. Then you can drill it or machine it as required.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
GREYHOUNDMOSES
posted March 23, 2011 11:58 AM
Thanks Guys,
Once again I've managed to stumble blindly past the bleedin' obvious!
The carbon fibre I'm going to use is a "finished" piece, but I'll just roughen up the mating surfaces
before applying the resin.
0.21157789230347 seconds processing time
