BIKELAND > FORUMS > ZX-14.com > Thread: Anyone with a turbo map? NEW TOPIC NEW POLL POST REPLY
gilberjj
Friend of Fast
posted March 17, 2011 11:36 AM
I know 1bad and 01smokes have e85 turbo maps with larger injectors. I have 700cc injectors, and I'll be using a 1:1 rising rate regulator. If anyone has a map that will work as a base map, I would greatly appreciate it. I'll be getting my bike professionally tuned, but it would be great to have a base map to make sure I have all the bugs worked out BEFORE I get the bike to the dyno.
Thanks,
Jorgen
If you have a map you don't mind sharing (e85 or gasoline), please send it to...
gilberjj@gmail.com
Please state what psi it's tuned for, base fuel pressure (what type of regulator used), and size of injectors. Thanks again!
Foster
posted March 17, 2011 08:47 PM
I have a map for the Bazzaz. I have 840cc injectors and run E85 with 8lbs of boost at about 55lbs of pressure with 1:1 rise during boost and turbo pistons. I really only have it tuned for WOT.
You will probably be pretty close/safe at 0 map with those injectors and 8lbs. I am all negative all the way through between -20 and -9 (WOT). And at idle I have it at -35.
johnbull
posted March 18, 2011 12:43 AM
All I can offer you is a PCV map of my supercharged ZX14. Are you running on a fixed map or are you using a map sensor signal to map according to boost?
John Bul Racing. Malta.
gilberjj
Friend of Fast
posted March 18, 2011 05:47 AM
I have an external map sensor
gilberjj
Friend of Fast
posted March 21, 2011 03:49 AM
Art????
gilberjj
Friend of Fast
posted March 23, 2011 09:48 PM
Bad guy????
miketmmns
posted March 24, 2011 03:39 PM
I have a map for an atp kit. I dont know if it will work for you or not but if you want it i can send it to you.
0.21781802177429 seconds processing time
