BIKELAND > FORUMS > ZX-14.com > Thread: How to increase oil volume while using a street pipe? NEW TOPIC NEW POLL POST REPLY
BLK ICE
posted March 13, 2011 06:46 PM        Edited By: BLK ICE on 14 Mar 2011 02:49
Is there a way to increase oil volume while using a Street pipe (Brock Street Meg) such as a larger oil filter etc? I currently have a OSR pan. I want the additional oil for safety while spraying. Thanks for any help.
1badzx12r
posted March 13, 2011 08:31 PM
http://www.schnitzracingstore.com/catalogs/catalog.asp?prodid=5032336&showprevnext=1
NINJA12
posted March 14, 2011 08:27 AM
Add a little extra oil, 1/3 - 1/2 quart maybe.
You may loose a little hp down low, but you would not suck the pan dry up high.
Ive heard of the loss hp on a dyno, i don't see how it can hurt going down the track where the oil is in the head ,low and pushed to the rear of the pan from acceleration.
BLK ICE
posted March 14, 2011 10:52 AM
Thanks for the help guys.
I just ordered the 'Heavy Duty Oil Pump Cover" I have already increased the pressure. I will put a little more oil in and remove the catch can. Does anyone know of a large oil filter or something to increase volume?
Ozonkiller
posted March 14, 2011 07:24 PM
Mobile 1 filter M1-110
Napa Gold 1356
Both are a bit longer with more filter media surface area.
I've cut them both open. Good stuff inside.
I've run them both on my BMW for almost 140K miles and on my 14 for a while with no problems at all.
I hope this helps,
Tom
zx14fan
posted March 14, 2011 10:55 PM
oil volume ? Imo You really dont need more then stock and may never will.Thats a mistake some people make building drag cars. you reallty dont need much more then stock.Its harder on bearings and harder on the oil rings.unless you have a real thumper that screams the stock pump works fine.
billeason
posted March 15, 2011 05:02 AM        Edited By: billeason on 15 Mar 2011 13:17
In the 14's case this would be wrong ! Anything you can do to supply a better volume of clean oil to the kaw's
This wouldn't be a problem so much but the motor also has a oil feed system to the rods that don't lend itself well to good oil supply
bill eason
gilberjj
Friend of Fast
posted March 16, 2011 11:39 AM
The schnitz oil pressure release valve raises pressure a LOT though. 110 psi is a LOT! In your opinion, is that better then stock? I've heard that the real problem with the kawi's oil system is the lack of oil FLOW (as in volume of oil flowing past the bearings), not the pressure itself. I suppose increased pressure will increase flow to an extent, but not dramatically.
billeason
posted March 16, 2011 12:56 PM
Go with a good pump cover,and seal it well'' one of Jim's gear set ups imo would benefit more then the high psi relief by itself .
Plus the relief is at high end of scale it does nothing at lower speeds..............
bill eason
0.26072597503662 seconds processing time
