BIKELAND > FORUMS > ZX-14.com > Thread: Zx14 turbo fuel system questions NEW TOPIC NEW POLL POST REPLY
gilberjj
Friend of Fast
posted March 06, 2011 08:18 PM
As you all know, I'm building my turbo bike to run on e85. That requires a lot of fuel, and I'm not sure exactly how I should set my fuel system up...
Here's what I have...
Walbro 255 in tank pump mounted in the 06 housing
Aeromotive 1:1 fuel pressure regulator
Bosch 700cc injectors
The way I was planning on providing fuel was to use the stock line to get the fuel to the rail, weld on a 90 degree -6an fitting to the fuel rail, then use the aeromotive fpr, and return the fuel to the tank using a weldless tank bung from cycle logic. This seems to be the easiest way to do it, but I still have a few questions.
How do I bypass the stock internal regulator?
Will the stock fuel line and tank fitting support my fuel needs (about 500 hp of gasoline)?
Thanks,
Jorgen
Big_T112
posted March 06, 2011 08:43 PM
I mounted my pump external. I guess my pics are on my old computer which is in the closet. I will try and drag it out and post up some pics.
gilberjj
Friend of Fast
posted March 06, 2011 08:49 PM
Did you use the stock fuel line?
01smokes
posted March 06, 2011 09:48 PM
im running -6 feed and return i didnt want to have it get choked up with the stock line
PayPal, vigilart22@yahoo.com
Email, artvgl@yahoo.com
Compton
posted March 07, 2011 04:07 AM
get a 08+ housing. same as a zx10r and i believe zx6r. just get a flat one. it makes running a feed and return a lot easier.
b.w.
01smokes
posted March 07, 2011 10:01 AM
+1 I'm running the zx6 one in my bike.
0.22281289100647 seconds processing time
