BIKELAND > FORUMS > ZX-14.com > Thread: Need some help... NEW TOPIC NEW POLL POST REPLY
posted March 04, 2011 03:42 PM
Need some help...
Can anyone tell me the torque specs for the clutch cover & clutch spring bolts on the 14 ???
kawasakijockey
posted March 04, 2011 04:01 PM
9.8nm, 87in. lbs., 7.2 ft lbs. for the cover. Spring bolts are 8.8 nm, 78 in lbs., 6.5 ft. lbs...... In other words a good hand tightening will work great.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
posted March 04, 2011 04:09 PM
THANKS.....KJ
kawpower
Mr kawasaki 2 you!
posted March 04, 2011 04:15 PM
9ft lbs i dont hand tighten nothin ,esp nothin thats important.
kawpower
Mr kawasaki 2 you!
posted March 04, 2011 04:19 PM
and a little oil on those spring bolt threads before install is a good idea too.
kawasakijockey
posted March 04, 2011 04:21 PM
6-7 ft lbs. NOT 9ft lbs.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
zxbob
posted March 04, 2011 05:40 PM
Bob
posted March 04, 2011 08:27 PM
Thanks Guys...
See you @ E-Town Sonny...
kawpower
Mr kawasaki 2 you!
posted March 05, 2011 06:39 AM
u got it rick, i will be there on the 09 streetbike, elvira is to long now to enter tsb . and yes 9ftlbs ,since 06 i have never pulled any threads out nor have i lost a bolt or had a leak,on the other hand i have seen a few that did by hand tighting and an uncalibrated torkwrench that was set at 6-7 ftlbs ,and it was ugly and costly for the owners. 9ibs and a little oil on them there threads and no worrys.
kawpower
Mr kawasaki 2 you!
posted March 05, 2011 06:42 AM
p.s. get yourself a afm rubber gasket from cometic ,it is reuseable manytimes over and is way cheaper than oem.
posted March 06, 2011 05:20 PM        Edited By: CrotchRocket on 7 Mar 2011 01:22
Thats the same spec as the 12, never had a problem with it on the 12 & never put oil on the threads...
Whats up with putting oil on the bolts for the 14?
Is that only for the heavy springs or using the brock shims?
posted March 06, 2011 06:03 PM
No need for oil on the bolts, imo.
kawpower
Mr kawasaki 2 you!
posted March 07, 2011 06:12 AM
a more accurate torque value,and saves the threads from premature wear.
0.48965787887573 seconds processing time
