BIKELAND > FORUMS > ZX-14.com > Thread: Need Advise on Gearing for SWB NEW TOPIC NEW POLL POST REPLY
jarhead
posted March 02, 2011 04:13 PM
I am going to ride my 09 SWB this year to see how it goes. While I have been racing stretched bikes since 02 I have very little experience at SWB. I raced my 04 zx10 stock length a handfull of times waiting for Trac Dynamics to get around to building me an arm. That was not a pretty sight. Damn thing might as well have been a two stroke dirt bike leaving the line! What gear would you guys reccomend for a 155-160 lb rider. Bike will be strapped and lowered with three hole links. Muzzys pipe, fly's out, BMC filter, and will be mapped by Ryan.
ZX14Mike
posted March 02, 2011 04:31 PM
16/42
posted March 02, 2011 04:58 PM
I liked stock better than 16/41. Dropping one down in the front made it wheelie a lot more and I didn't get any faster.
dakota9498
posted March 02, 2011 05:06 PM
17/40 is what I always hear for swb.
2008 ZX14
Nelson Taylor
posted March 02, 2011 06:40 PM
stock was best for me,
Best #'s
1.54
4.03
6.02 @ 121mph
(Stock Wheelbase) 2006 ZX14
posted March 02, 2011 07:10 PM
17/40
ZX14Mike
posted March 02, 2011 07:26 PM
Do you guys think the 14 is that wheelie prone that stock gearing is best for SWB?............maybe because i'm at 4500 feet its not as wheelie prone......but I liked a little more gearing.
jlewis02
posted March 02, 2011 07:31 PM        Edited By: jlewis02 on 3 Mar 2011 03:33
Where you at mike?
When I was in ABQ 5400ft my bike wanted to come up but it was still controlable
Im 154lbs in gear and my bike is 16/41 but im going to run stock gearing this year maybe even 17/40
08 ZX14
1.57 60'
6.09@124
9.24@155
SWB 5400ft DA 50hp shot
smokehouse4444
XX to ZX
posted March 02, 2011 07:35 PM
Dropping a tooth in front was the biggest mistake I made when starting out on the 14. I'm 260 in gear, and I ran a 10.74 first time out. Then I dropped to a 16T, dropped 30lbs and added almost 20hp with Brocks exhaust, and I went backwards on my times. I fought with the thing like a wild animal. VERY good jockeys would race my bike and say it was one of the hardest they had ridden. I should have left it stock at SWB. Now, if my bike was SWB, I would run 17/40, like smokin said.
2008 Atomic Silver ZX-14, Brock's this and that, some other stuff, 260 in full gear, powered by Cheese
2005 Ducati 999 with all the goodies
ZX14Mike
posted March 02, 2011 07:46 PM
El Paso TX........it comes up occasionally but its controllable I'm WOT real quick probably after 60FT I would guess.........but its been A LONG time since I hit the track so i'm sure I'd be REALLY rusty.
jlewis02
posted March 02, 2011 07:59 PM
I run in roswell but want to goto more tracks this year
17/40 sounds like its the best
What sprocket brand would ya'll recomend?
08 ZX14
1.57 60'
6.09@124
9.24@155
posted March 02, 2011 09:36 PM
I have run 16/41 at stock wheel base and was able to run 6.0s in the 1/8 mile but i was allways fighting wheelys ... I switched back to stock and that helped me get into the high 5.90s ... I found out Ricky G was running 17/40 and Brock was running the same 17/40 gears on his ZX14 ... So i gave it a try and ran my best ever passes ( 5.80s ) at stock wheel base .. Now you need to understand my setup may or may not be the best for someone else , we all need something a bit different to fit our riding style or skill level .. You may have to try a few different gears to see what works for you ..
gilberjj
Friend of Fast
posted March 02, 2011 10:37 PM
I ran my bike at stock wheelbase quite a bit. I had best luck with 16/41. I weighed 230 lbs unsuited at the time, and the extra gear helped me get out of the hole. However, now that I've had more experience racing my bike, I think I'd actually do better with stock gearing. I think short gearing helps when you're not as good, but then as you get better, I've found that I dont need the short gearing to go fast. Just a thought.
BobC
posted March 03, 2011 12:28 AM
I'm with the others on this, I was geared 17/40 on a stock wheelbase, lowered and strapped and got it into the nines.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
jarhead
posted March 03, 2011 05:07 AM
Thanks for all the help guys, I always try to error on the side of caution. I have seen first hand what happens when guys get too aggressive. I guess the good thing is sprockets are not that expensive. A plus side to dropping a tooth on the rear would be free wheelbase. I am looking forward to it, should be fun.
Quarter Pounder
with Cheese
posted March 03, 2011 07:21 PM
I run 17/40 Works great for me.
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
Beondwacko
posted March 04, 2011 09:07 AM
I'm running a 16/40 combo and I just got the bike down to a 9.61 @ 151.3 weighing in at 225 in leathers. It's a winning set up for me.
jarhead
posted March 04, 2011 06:04 PM
I am hoping for 9.50 on pump gas, we will see.
0.31318402290344 seconds processing time
