BIKELAND > FORUMS > ZX-14.com > Thread: removing the Alternator Rotor NEW TOPIC NEW POLL POST REPLY
MotoCycho
posted February 17, 2011 12:48 PM
I tried the search feature on this forum with no luck.
Anyway.. tearing into my 2007 motor with a spun rod bearing.. just about ready to split the case. I don't mind buying the Kawasaki tool or perhaps a motion pro tool if it works.. but is there perhaps another trick I can try to get the alt rotor off? The crank has definitely got to go to a machine shop to have the #3 crank pin cleaned up. Can any one confirm the Motion Pro tool will work?
watthecu
PissingContestHere
posted February 18, 2011 09:23 AM
Motorcycle axles - Find the right mm and thread pitch.
Ozonkiller
posted February 18, 2011 07:02 PM
Won't work. The rotor has external threads
0.25526213645935 seconds processing time
