BIKELAND > FORUMS > ZX-14.com > Thread: wire for rpm window switch? NEW TOPIC NEW POLL POST REPLY
pazx14rider
posted February 05, 2011 05:39 AM
Does anyone know what wire I use to pick up the rpm for a dynotune rpm window switch?
dakota9498
posted February 05, 2011 06:14 AM
I would think that it would be coil wire number 1. White/Red, you should be able to pick it up back at the ecu.
2008 ZX14
pazx14rider
posted February 05, 2011 09:00 AM
Tried that wire went through all the programming procedures of the window switch everything was ok except the rpm hmmm
GREYHOUNDMOSES
posted February 05, 2011 09:18 AM
What was the switch set at and what was it switching at?
BrucerZX14
posted February 05, 2011 10:59 AM        Edited By: BrucerZX14 on 5 Feb 2011 19:04
I have a Dynotune RPM window switch on my ZX14. I picked up the signal from the #4 negative lead on the coil. The setting on the RPM window switch for the tach input is 001. Works perfectly.
I have a friend that picked up the TPS signal at the ECU nad has issues. I really think the closer, the better from my past installs.
0.23756909370422 seconds processing time
