BIKELAND > FORUMS > ZX-14.com > Thread: What's the torque spec for the head bolts? NEW TOPIC NEW POLL POST REPLY
gilberjj
Friend of Fast
posted January 06, 2011 03:35 PM
Like the title says. What do I torque the head bolts to? Would another 5-10lbs work?
posted January 06, 2011 04:01 PM
NO .. TQ them to factory specs !!!!! Unless you are using head studs , if so use the spec that comes with the studs ..
06redzx14
posted January 06, 2011 04:27 PM
17ft lbs initial and 52ft lbs final I think I'll check my manual when I get home
gilberjj
Friend of Fast
posted January 06, 2011 04:46 PM
28 initial. 52 final
johnbull
posted January 07, 2011 12:41 AM
52ft lbs final on stock bolts. What should it be when using the APE HD head studs?
John Bul Racing. Malta.
johnbull
posted January 11, 2011 12:57 AM
bump
BIKELAND > FORUMS > ZX-14.com > Thread: What\'s the torque spec for the head bolts? NEW TOPIC NEW POLL POST REPLY
0.2521710395813 seconds processing time
