BIKELAND > FORUMS > ZX-14.com > Thread: How long does it take to install valve springs NEW TOPIC NEW POLL POST REPLY
gilberjj
Friend of Fast
posted December 21, 2010 06:08 PM
How many hrs does it take to install hd valve springs? Is it easier to drop the motor or do it on the bike?
posted December 21, 2010 06:11 PM        Edited By: Shane661 on 22 Dec 2010 02:13
Unless you make a setup to pump compressed air into the cylinder, you won't be doing it on the bike....
Besides, it would be a huge PITA trying to fit the keepers with the head on the bike, imo...
I thought you were changing the head gasket anyway??
Compton
posted December 21, 2010 06:26 PM
takes me and my friend around 40 mins slowly paced to have the engine on the bench. a lot easier 2 work on too
b.w.
posted December 21, 2010 06:42 PM
How are you keeping the valves from dropping?
gilberjj
Friend of Fast
posted December 21, 2010 06:59 PM
Great, that's what I needed to know.
gilberjj
Friend of Fast
posted December 21, 2010 07:02 PM        Edited By: gilberjj on 22 Dec 2010 03:02
My friend has a air fitting with spark plug threads that allows you to compress the cylinder. That way the valves won't fall into the head once the keeper's removed.
Also, I don't know that it's worth the hassle putting on a thicker head gasket. However, if I'm removing the motor, maybe it will be pretty easy to change out the head gasket.
Compton
posted December 21, 2010 07:17 PM
bubblegum. j/k
air or just take the head off
b.w.
Big_T112
posted December 21, 2010 07:22 PM
It is a lot eaiser with the head off and a valve spring compressor.
1badzx12r
posted December 21, 2010 08:26 PM        Edited By: 1badzx12r on 22 Dec 2010 04:30
hell yeah .. motor out of frame too ..
i'm doing mine right now ..not in a hurry because i make mistakes when i rush a job .. about 7 hrs into it right now .. removed motor from a complete fairing bike .. valve adjustment and alot of cleaning
Big_T112
posted December 21, 2010 09:14 PM
well you can lean the motor forward and just pull the head.
1badzx12r
posted December 22, 2010 05:31 AM
i don't have to even lean the motor to pull the head . but its soooo much easier to do everything with motor pulled .. but i also going to rewire or rerout all my aftermarket wiring. .
NINJA12
posted December 22, 2010 09:03 AM
I'd like to see the tool you use to compress the springs with the head on.
air in the spark hole is simple compressing the spring and getting keepers out and back in?
1badzx12r
posted December 22, 2010 10:16 AM
i wanted to see the how to video ..
Big_T112
posted December 22, 2010 10:24 AM
all the air does is hold the valve against the seat. I have always removed the head. I have never tried using air, But that's just me.
Compton
posted December 22, 2010 11:11 AM
haven't done it that way on a bike, its always too simple to pull the motor or head.
But on LS1 based cars they make a tool for it, thats the only time i've done springs with the heads on the motor in the car.
b.w.
0.2966411113739 seconds processing time
